Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer (electric)
My dryer is two years old. Yesterday I pushed the start button, dryer would work but stopped in about one minute. I pulled out the dryer and cleaned the vent. The dryer then worked. Today I pushed the start button, and it would not stay running. It runs as long as the button is being pressed. (Not a good thing, if you have other things to do and cannot stand there and hold the button in!). I empty my lint trap with every use...Any suggestions would be VERY helpful. Thanks. You guys have a great web site.
  • 1 more comment
  • Seneca Oct 05, 2007
    Thanks for your help. I will try replacing the switch. I can't remember if it clicked when I pressed it or not. Sure hope it is the switch and not the start relay.
    The switch is on it's way to me. Had to order it, I live out in the sticks. It will take 7 business days to reach me. I'll let you know.
    Thanks again.
  • rdysz Jul 21, 2008
    The dryer is getting power but will not start.
  • 209 Answers
Did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Posted on Oct 04, 2007
  • mick d Oct 05, 2007
    if you buy the switch over the counter, ask if it clicks, if the answer is no it doesn't then it may be the relay, the cost of the switch should be peanuts so it wont hurt buying one anyway, the relay shouldn't be that expensive (if it has one fitted) so well done, start with the switch, let me know how you get on, thank you
4 Suggested Answers
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
  • 2651 Answers
SOURCE: roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Posted on Feb 24, 2008
  • 236 Answers
SOURCE: Lint trap allows too much lint to pass thru.
If the vent is in a vertical arrangement you will need to have a chimney sweep(they are around) or get a cleaning kit for a 4 inch duct(18cm) from a place like Harbor Freight tools($10-15 USD). Doing it your self will be much less expensive. The lint filter can not catch every thing. If it is dammaged replace it but the durt will need to be cleaned periodically due to the nature of the incline. You will also notice faster drying times caused by improved air circulation. Be sure your dryer duct between the machne and the wall is cleaned, hooked up and not collapsed. If this is helpful please leave feedback. Thanks,SnugglePants
Posted on Nov 03, 2009
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Jun 25, 2009 | Kenmore 659 Electric Dryer
Dryer wont come on and light on the inside doesnt come on
this could be that your belt is broken there is a switch when the belt breaks it stop working thanks from gilles
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Dec 30, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
161 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
