Question about HP LaserJet 1320n Printer
Printing on Stationary with an HP Laser Jet 1320
When we print a letter on our firm's stationary, which paper is known as 24# Bright White Strathmore writing wove, fold the letter into thirds and put it into a 9 1/2 by 4 1/4 size envelope and then mail the letter. Some letters have been returned to us for whatever reason and when we open up the letter the ink has rubbed off, leaving a shadow of the printed paragraph, depending on the way it is folded. This looks messy and unprofessional. When the letter is mailed the ink is dry, it does not rub off to the touch. The print cartridges we use are manufactured by HP and not recycled. Any suggestions on how to rectify this problem.
  • kimg Oct 11, 2007
    There is no option for cardstock.  What now?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Posted on Oct 11, 2007
  • CheckitRight
    CheckitRight Oct 12, 2007
    It should be there, did you get to where it said paper quality? Did you click on it? there is an option for paper option click on it and go to TYPE ( for what type of paper)
  • CheckitRight
    CheckitRight Oct 28, 2007
    Any news on the word on the ink rubbing off, after you,ve adjusted it?
SOURCE:
Printmaster half-fold printing on epson printer
Before printing you need to select the size and orientation and it's a good idea to look at the preview before printing. That saves a lot of paper.
Nov 19, 2017 | Epson Office Equipment & Supplies
Letteres printed on a Monochrome printer offset type onto themselves
Which print finishing setting do you use: Draft, Normal or Best?
Mar 07, 2008 | HP LaserJet 1320 Printer
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
For a Swintec 8014 typewriter: the bottom portion of the letters are not tranferring to the paper when the keys are striked. although the ribbon shows the full letter being striked, only the top portion...
Check to be sure the ribbon dosen't have a fold in it and is fully seated in place, be sure the platen is fully seated in the side frames, check the correction tape for proper imstallation it can rob the print if to high.
DickyO
Dec 03, 2010 | Swintec Office Equipment & Supplies
AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
May 18, 2010 | Sharp AR-5320 Black and White Copier
Installed new ribbon. appears correctly installed.
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
DickyO
Oct 02, 2009 | Lexmark Wheelwriter 15 Series II...
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
Jan 06, 2009 | Office Equipment & Supplies
Toner prints onto adjoining paper in the mail.
maybe it is excess toner, or the paper type my be the wrong type to use, try some other type
Nov 17, 2008 | Canon imageCLASS D880 All-In-One Laser...
Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Jan 08, 2008 | Dell 3100cn Laser Printer
HP LaserJet 1320n Printer Logo
217 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
