Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
TV is showing an error code when I go to turn it on.
I replaced the lamp in it with a Toshiba unit ($199.00) about 6 months ago and it's seen very little use since then, but now the TV is showing an error code when I go to turn it on. It tries to turn on 8 times, then flashes both the green and red LED together. If I keep trying for a few hours, eventually the TV will come on and it'll stay on indefinetely, but once you turn it off it may take hours to get it to turn back on again. So, as far as I know the lamp is still good. I pulled it out and there are no signs of a blown lamp or anything like that. Any ideas what coud be wrong and will it be expensive to fix?
  • 1 more comment
  • rmeate Oct 04, 2007
    TV is a Toshiba 46HM94 46" DLP HDTV
    A Toshiba rep told me on the phone it may be that the "Light Engine" went bad any idea what that is and how could I check that?
    this TV only powers on once in awhile and I don't know what is wrong with it, or what it will take to fix. I think the lamp is still good. wonder what I can get for it if I try to sell it as is
  • 1,139 Answers
The reason the set is not coming on is because the shutdow circuit is doing what it is supposed to do. The TV might be experiencing some sort of current overload which disappears after a time. However if this is the case here is a possible way of troubleshooting this problem. get a schematic and turn to the power supply section turn on the TV and measure the output voltages of the power supply then measuer the voltages in the horizontal section to determine if the HV section which is part of the horizontal section is working properly. I believe that your problem lies somewhere between the low voltage power supply (switching transformer based) and the high voltage power supply (IHVT based). Make sure to check your fuses. Now this is a start, the point is you need to find out if the problem is or is not a power supply issue.
Posted on Oct 04, 2007
  • Henry McKelvey
    Henry McKelvey Oct 04, 2007
    The light engine is entire light generating assembly all 3 tubes and the associated circuitry. Also this term is used to describe the DLP assembly in DLP typ projection TVs. Ins short the light engine is:
    The optics
    The circuitry
    The light source (tubes, leds, or DLP)
    DLP = Digital Light Processor
    I hope this helps.
I have toshiba 50hm67 replaced worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Sony KDF-E50A10 stays on for 15-20 minutes then shuts off power standby light flashes green and turns back on. Replaced bulb about 6 months ago with sony bulb. Any ideas. Thanks
The reason this happens the most is because of the lamp being weak. I have not seen anything else cause this problem. You can varify this by turning the set off and wait until it shuts down totally.
with the Sony remote, press the display button, the #5 button,
volume down button, then power button. This puts you into the the factory error code mode. If you see the lamp code with multiple errors and no other errors shown, the lamp is the problem.
Most of Sonys lamps have a aprox life of 3000 hrs. Some last longer and some shorter.
I hope this helps,
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba dlp 42in. keeps shutting off . replaced lamp 5 months ago
it sounds like your lamp could be failing. check your lamp it should be clear with no frost.. here is your lamp part number 72620067
Mar 15, 2009 | Toshiba 42HM66 42" Projection HDTV
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
