Flow Indicator Not Moving, Not Dispensing Anything
Does water squiret out of the hose, if it does, then check the heater inside the handle to see if it is clogged where the 2 water lines hook to it. The other reason, you may ghave a bad pump. But check the back edge to make sure the top isn't coming loose from the base. Check the bottom of the tank to be sure round seal is on the tank on the cap and valve. Sometimes they come off and wind up in the hole.
