Question about Sherwood Hollywood-at-Home VR-670 System
Dvd will not load
Load icon just go arond dvd won't load.....never says disc not found
0 characters
1 Points
Why my system eject cd/ dvd and after that i use combinition keys eject+ stop to lock it, it dosen't read the disc and show's no disc in. how i can fix it?
You can't. CD/DVD or even VHS have sensors. Sensors sending information about empty or loaded. Can be laser are broken too. Laser after loaded dick try to read out information from disc, but if no info, device understand like 'empty disk' or 'just no disk'.
You can try to buy CD/DVD cleaning disc for laser clean, but if driver can't find disc perhaps it not help.
Mar 23, 2016 | Home Theater Systems
DVD+R won't run on Sanyo DVW-6100
you need to burn the video on a memorex DVD-R disc and then it will play
Jan 20, 2013 | Sanyo DVW-6100 DVD Player/Video Cassette...
It won't open
i bet t is the belt for the tray motor, mine hs the same issue, i took it apart ad found the broken belt, jut have to find the replacement
if you remove the steel cover from the top of the unit you will see the disc, there is a bracket above it which can be removed with two screws and take the dvd out easily
May 19, 2012 | RCA RTD315 Theater System
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Dvd player reads no disc and than shows loading
Have you tried other DVD' might have a bad one.
If so,,,you may need to clean the laser diode. You'll need cottonless swabs (no lint swabs) and Isopropyl alcohol 99%.
Might be hard to get to, depending on the model, but gently swab the diode lens. Don't saturate it tho.
good luck
Apr 07, 2009 | Samsung HT-X810T Theater System
Xv-dv333 won't load dvds
Try running a cleaning disc. After that it worked for me.
I have a XV-DV323
Nov 29, 2008 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
Aug 20, 2008 | Samsung HT-WP38 System
Won't play purchased dvd's
I just found the unlock code for the t342 says to turn player on without a disc insetred then press setup go to preferences press 1379 select region 0= multiregion
Sep 22, 2006 | Amphion Mediaworks T342 System
Playing dvd's
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more. P.S. please use line breaks between paragraphs and one "dot" at the end of a sentence is enough.
Nov 30, 2005 | JVC TH-A9 System
Sherwood Hollywood-at-Home  VR-670 System Logo
450 people viewed this question
Top Sherwood Home Theater Systems Experts
Gyula Lacz
Are you a Sherwood Home Theater System Expert? Answer questions, earn points and help others
