Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
Help to connect the cordless itouch keyboard
I am trying to install cordless keyboard and mouse to use with my PC. I got it from a person who was using a windows Win XP OS and I have the same OS. No manual or software but I got the driver online The mouse works but the keyboard doesn't work. When I go to the configuration and press the connect buttom it give me the mgs (to connect to a new device insert battery and press its connec/channel buttom) I don't see any connect buttom on this keyboard. Wherre is the connection buttom on this keyboard? I tried to use the connect button on the mouce and the one on the receiver but still no connection. Any idea woud be very appreciated
  • Sarah Emmanuel Oct 04, 2007
    got it...wow thanks so much...almost take this to the salvation army
  • 661 Answers
I had one of these if it is the same model it is on the right hand edge (not on the underside not on the top) between where the number pad is but below the indicator panel, the button is small and I think red and recessed(so you need to use a biro, or such like to press it) silly place to put it, most keyboard connects are on the bottom now
Posted on Oct 04, 2007
2 Suggested Answers
SOURCE:
SOURCE: Help with my keyboard connection
IGNORE mgs "to connect to a new device insert battery and press its connec/channel buttom" - pressing the CONNECT button (right side of the keyboard) simultaneously with the TRANSMITTER button will do the job.
Posted on May 06, 2008
Can someone help me. I forgot to reboot or reset my itouch 2.15
To reset the iTouch so that it connects afresh to the USB receiver, there's a small inset button below the keyboard (and another under the mouse). Try keeping it at around three feet from the receiver when you do that; sometimes, too near does not work very well, and of course too far won't work at all. For the mouse, you will probably need a pin or a ballpoint pen to be able to press the button.
Feb 28, 2010 | Logitech Cordless iTouch Keyboard/Cordless...
Tip
How to connect a Logitech Cordless iTouch Keyboard with a Nono receiver ?
I would like to connect my old Logitech Cordless iTouch Keyboard with a Nono receiver ? (to remove the old PS2 receiver)
Is it posible' ?
Thanks and best Regards
on Sep 02, 2012 | Logitech Cordless iTouch Keyboard/Cordless...
How do you hook up wireless keyboard
Remove the battery of the keyboard if is not working and install new one and then press connect button from the mouse side and the receiver side also.
Nov 27, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Recognizes wireless mouse but not keyboard.
may not be compatible,
or you ay need new batteries for the keyboard
Apr 18, 2009 | Compaq Computers & Internet
I need to locate the reset button on my itouch cordless keyboard
look at the side on the right of the keyboard just beneath the grey area. Its a round grey button with no labelling. Press the connect button on the IR module or the itouch icon on your system tray then press this button.
Jan 06, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech iTouch key board
Have you replace the batteries? If so try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 23, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
The keyboard must still be connected to the back of the computer. The keyboard is only wireless to the transmitter. Check line of sight to transmitter. Double check all connections (wires) to the computer. Unless something is damage most all wireless keyb are quite reliable.
Oct 04, 2007 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
3,008 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
