Question about HP PSC 950 All-In-One InkJet Printer
Print 5x7 invitations on my 950?
I bought 5x7 invitations assuming I could print them on my 950. I can't seem to figure out how to load the paper or how to get the printer to line up correctly. I wrote up the invitation in Word and made it a 5x7 document. Somehow the margins aren't lining up?? Please help!! It is expensive to take it to Kinkos! I know it should be able to do it!
  • Anonymous Mar 28, 2014
    load print paper
I am having the same problem trying to print a 5x7 invitation from a Quark Xpress doc. When I set the printer perameters to 5x7, it still doesn;t work...... Any suggestions????
Posted on Jun 24, 2010
    Problem Solver:
  • 10 Answers
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Posted on Oct 06, 2007
How do I print postcards on HP PSC 950
Hello!
Here is your solution to print postcards size.. 1. Select your image and press mouse right . 2. Select print and select your printer. 3. There may be many sizes indicate there... but you must select 4x6 or 5x7 as it is postcard size. 4. Now select your paper quality (eg. Photo paper plus glossy ) 5. Press print.... That is it .... good luck
Sep 08, 2011 | HP PSC 950 All-In-One InkJet Printer
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
How can I print invitations size 5X7 on this printer.
You need the driver setings on your pc, select the correct paper type or media type then select the size if this size is not available you can create a custome paper size one the driver but you must take into consideration on how thick is your paper you can set the media thicker setting all this option is available on the printing preference (windows) or print settings (mac).
hope this help
May 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
I am trying to print onto 5.5w x 8.5h invitation paper. What settings do I need to use? If I select the paper size and put it in the printer, it will not print .... expecting regualar size paper.
Have you tried the upper level tray of your printer?
Go to the Print command
Select Properties
Go to paper source
Select upper tray (Be sure tray is loaded with paper)
select OK,
select OK
Jul 14, 2009 | HP PSC 950 All-In-One InkJet Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing 5x7 invitation
use the mpf tray. go to the machine press menu down arrow untll you get to tray settings. right arrow over till u get to paper type...then down arrow till you see paper size...right arrow again till u see tray 1...down arrow till you see mpf..right arrow till you see letter. Now that you are in the mfp section you can down arrow and you will see serveral selections I would keep it at letter. when you select it an * will appear next to letter. Then select menu and you and the printer is set. Now go to the print option in the program that you are using and when the dialog box to print opens select properties. go to paper quality the mpf should be selected in the tray souce. Now go down and you will see the advance button, click on that you will see Paper/Output make sure it says Paper Size and Letter is selected. Media Type should say Plain 1. If the invitations is on a heavier paper like card stock click the down arrow and select Covers 1 . If your paper is coated like matte finish photo paper select Coated 1. Now click ok. Do a test print and see if you get what you want. If not, let me know.--Deeva
May 21, 2008 | Dell 3100cn Laser Printer
Trying to print an invitation
1. load your blank card in rt side of the tray
2.keep your card matter left top of your computers file then try
first you can try it with your 8.5" x 5.5" peace of papper.
this can help you
Mar 08, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
2,165 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
