Question about RCA P52930BL 52" Rear Projection Television
RCA 52" Rear Projection P52930BL
Convergence is off. All 3 colors are misaligned. Don't have original remote to use to try to reset. How do you replace convergence?
  • 1 more comment
  • iamcanadian Dec 30, 2007
    I have a RCA 52" P52930BL and all three colors are misaligned. I recently hookup an XBOX to this TV and since then this is what happen. I don't know if it is related. Sometimes the TV will work fine if I unplug it for a period of time but this will reappear at anytime.
  • craignardo Mar 28, 2009
    same problem but i do have the adjustment available for the convergence , set is ok for a min or so when turned on them convergence goes way out of wack any ideas
  • a_heart_full Apr 05, 2009
    52 inch rear projection clear pic but people have green red and blue ring around them?
  • 61 Answers
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Posted on Mar 06, 2008
How do i replace a convergence power supply on an rca 52 inch projection tv
The convergence power supply is the small narrow board which is held in place with a couple of screws. I am attaching a pic of the board yours may be slightly different 8_9_2012_4_22_22_pm.jpg
Aug 09, 2012 | RCA P52930BL 52" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I fix this problem with the color green misaligned? I checked the convergence board and power board to see if any fuses were burnt up but nothing. It only does it when certain things are on tv. For...
Did you try to do a hard reset to bring up your convergence option. Its been awhile but I think you have to unplug your unit for 24 hours . Then your convergence option will come back up.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
Colors are out misalignment power flipped ona nd off and sense then clolors been misaligned
The ITC222 and ITC222A convergence option repair kit from should repair that issue. The kit also contains the CD with instructions.
Jan 08, 2010 | RCA HD52W56 52" Rear Projection HDTV
How do u fix the security on a 52" RCA HDTV Monitor
You will need to reset your v-chip, refer to your manual for exact instructions if you do not know the code, or call RCA to get it reset.
Jul 15, 2009 | RCA P52930BL 52" Rear Projection...
Convergence off line
How did you fix it?????? I though I tried everything!
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need to do a convergence alignment on RCA rear projection unit.
replace convergence amp board.
this is a RCA tompson part number, you can find it on line the part number is.
PS thier are manny ways to repair your board and manny parts to look at its much less time consuming to just replace the board.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
P52930bl RCA Projection 52" Remote problem
First thing you want to do with this set would be to unplug it for at least a 24 hour period. if that does not work, the remote sebsor could be defective. if you want to just replace the sensor and not trouble shoot the set, it should be located behind a plasit cover in the front of the set, or located inside the reflection area of the TV set. Differant models are located at differant positions. If you have no electronic experience, play it safe and call in a trained tech to assist you in this repair. Good Luck Please do not forget to rate this thread.
Dec 14, 2006 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
