Question about Philips HTS3440/37 System
No sound I have picture and it plays dvd's just fine except there is no sound at all. I've tried unplugging everything and plugging it back in i've messed around with the remote to see if that would help. I found that if I turn the volume all the way up you can hear it but its barly audible.
  • 2 more comments
  • jthtt Jan 27, 2008
    everything works, just no sound
  • Anonymous Feb 16, 2008
    The rear right and left, plus the subwoofer are working but the rest of the speakers are not.
  • Holyghost Feb 16, 2008
    The rear left and right speakers plus the subwoofer is working but the rest are not.
  • Anonymous Apr 11, 2008
    Picture works, but there is no sound. Have to turn it all the way up to even hear a little bit.
First I will try the following
1. Go into the Setup Screen (via your remote), there are some audio setting. Change it to see it makes a difference. Make sure it is not muted.
2. change from 2 Channel to 6.1/5.1 channels. At the bottom of the remote, there are a bunch of audio setting, play with it and see if it makes a difference.
Posted on Jan 24, 2008
SOURCE:
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Panasonic DMR-ES20 no longer plays back picture on any DVD. Sound works fine, but no picture. Have tried with component, S-Video and RYG cables, but no picture.
I just had the same problem, Tried a bunch of things, ended up just unplugging it, letting it sit for a min and plugged it back in...fixed.
Jan 10, 2010 | Panasonic DMR-ES10 DVD Recorder
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
Can not change "Device" input, no sound control,no remote control
I unplugged the manual switch electrical connection. Everything works just fine with the remote.
Not sure what is wrong with the switches just yet, but suspect a resistor problem. I have checked all voltages and have 5.04 v feeding the switch assembly on what I feel are the correct circuits
(5v, ksco, ksc1, man/reset). I have no voltage on the ground circuit with the board plugged in, so the ground circuit should be ok. I have tested all switches with ohmmeter, all switches work. I suspect a resistor problem as I have one with no voltage drop and one resistor with no voltage pass-thru. Would need a wiring schematic with values to pinpoint better.
May 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
P46924 no sound great picture
Oh, I love easy ones like this. Unplug the set for one minute and plug back in. Voila !!!
Mar 30, 2009 | RCA P46924 46" Rear Projection Television
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
Disc tray will not open
It's messed up. Take it back to WallyWorld for an exchange.
Dec 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Clear sound with jumping picture
either the disc ur inserting is dirty or the laser needs cleaning try cleaning ur laser first then the disc if the problem prosist take the dvd player back
Aug 26, 2006 | Yahoo YDP305 DVD Player
Philips HTS3440/37 System Logo
227 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
