Question about Compaq Evo N110 Notebook
BEGINNING DUMP OF PHYSICAL MEMORY
I HAVE INSTALLED A MATSER DISK OF WINDOWS XP, ITS GONE TO A BLUE SCREEN AT THE END IT SAYS BEGINNING DUMP OF PHYSICAL MEMEORY DO I LEAVE IT OR HAS SOMETHING HAPPENED
  • CHASMAN2 Nov 28, 2008
    I HAVE A COMPAQ PRESARIO V 6000 IT SAYS A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SHUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER.
    REGISTRY_ERROR
    TECHNICAL INFORMATION:
    STOP: 0X00000051, (0X00000000,0XOOOOOOO1, OXOOOOOOOO,OXOOOOOOOO)
    PHYSICAL MEMORY DUMP COMPLETE
    MY PC KEEPS FLASHING THIS MESSAGE QUICKLY THEN SHUTTING DOWN THEN RESTARTING I WAS FAST ENOUGH TO TAKE A PICTURE OF THIS MESSAGE AND READ IT OFF MY CAMERA .
    I EVEN TRIED TO GET THE PC TO START IN SAFE MODE SO I CAN DO A SYSTEM RESTORE BUT IT WILL NOT LET ME IT KEEPS SHUTTING DOWN WITH THE SAME MESSAGE AND GOING THROUGH THE SAME CYCLE THE ONLY NEW THING WE HAVE LAST DONE ON THE PC IS TRY USING A NEW MICROSOFT WIRELESS MOUSE
    Brigadier General:
  • 6,966 Answers
Hi, Normally a blue screen of death (BSOD) with memory dump is indicative of a fault in the: Hardware- 1. Possibly memory; 2. video; or 3. motherboard. In some instances, Software- a. Drivers; or b. the Operating System itself. You may want to check the memory installed in your laptop. Some versions have them underneath the keyboard while most would have it at the bottom covered by a lid/plate secured with 1 or 2 small screws. The memory will spring out if you unlock the two side clips. You need to clean the little gold contacts with a pencil eraser. Re-insert back securely and try again. If the above does not correct the BSOD, you may need to replace them. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
After uninstalling antivirus my acer laptop has encountered by blue dump problem. there is no restoring points in safemode also. what i have to do?
You had to run the recovery disk which you got with your laptop .
if you don't have it you may call costumer support and ask for it.
if blue dump screen says beginning dump of physical memory.
uninstall av. and install any registry repair software eg.iolo system mechanic , regcure etc.
Feb 19, 2011 | Computers & Internet
Hi, my windows XP pro is no longer runing. i end up with a physical memory dump Screen. But no longer open on my desktop PC screen.
Download Malwarebytes from filehippo.com and run on both computers in safe mode
Go to start and right click on my computer click on properties and then advanced then startup and recovery click settings. Where it says write debugging info click(small memory dump (64kb)
Jun 27, 2010 | Microsoft Windows XP Professional Full...
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
ThinkPad Blue Screen of Death
Sometimes the blue screen can be caused by bad memory, but if it is doing it right when you try to sign in every time, it is probably a software corruption in windows. I have solved this problem by doing a repair install of windows xp, I am not sure if is an option on other os, if you google it you will find directions, you boot off the windows install disk and this option saves your programs and data.
Oct 27, 2009 | IBM ThinkPad T22 2647 Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Blue screen on my inspiron 6000
your hard disk has some eror it must need fixing.u can format your harddisk with win xp recobery disk.
Mar 16, 2009 | Dell Inspiron 6000 Notebook
Operating system
What part do you usually get the blue screen, you also need to know what kind of blue screen are you getting, for example beginning dump of physical memory or unmountable boot volume, then send me a message so that i can help you.
Nov 03, 2008 | Dell Microsoft Windows XP Home Edition
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Compaq Evo N110 Notebook Logo
1,018 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
