SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
SOURCE: Troubleshooting error message 79 00FE on LaserJet 8000N
Yes...if you remove the jet direct card and your error goes away, be sure it is the jet direct card. If it says 600, or 610 on it, those cards had a lot of problems.
You can buy these rebuilt very resonably.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: HP LASERJET M1522 NF 79 error what is it?
The unit has encountered an internal firmware error. If it's plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket. Retry the printer. If this fails again, then it looks like it would have to be a formatter replacement on the printer
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
