Question about ASUS A7S8X-MX Motherboard
On board sound and graphics
Hi, I'm not great at this computer stuff. I have just bought a used computer and I can't get get the on board sound to work at all, the graphics work, but when I drag something like a text box or window with the with the mouse,it sort of stutters along.Ithin it may be the driverss but I'm not sure. Any ideas how I can sort these problems? Cheers Keith
    Brigadier General:
  • 6,966 Answers
Hi Keith, If you are using Windows XP: Right click on "My Computer"; Click on Properties; Click on Hardware Tab; Verify that there is no Red or Yellow marked entry; If there are, then drivers are not installed or there is a problem; The drivers for the Asus A7S8X-MX are available at the Download pages of the Asus site. In "Input Model to Search", type "A7S8X-MX", in Select Category, choose "Drivers", click on "Search Info". On the new page click on link"A7S8X-MX", click on the "All" tab. Listed are all the downloadable drivers. Hope this be of some help to you. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
Why does my GM5420 Tower start up, but doesn't Read/Register screen?
I am not familiar with Gateway machines but this should work for most computers. You will have do some reading up. Yes it's probably a VGA (15 pin D-sub) the connector is often blue but can be any colour)
If your mouse/k-b etc are wireless they may need fresh batteries.
It may be the graphics facilities on your computer are u/s. It's quite awkward to solve this problem because you can't see what you are doing. You might try drivers for the monitor you are using (do not pay for these and be careful to void websites which are sources of adware or other malware) though this is unlikely as basic graphics are supplied in the BIOS
Try "gateway" support, or the "gateway" or other computer forums.
Read this http://www.pcguide.com/vb/showthread.php?70528-Upgrading-Video-Card-on-Gateway-GM5420
If there is a peripheral graphics card and your machine has on board graphics / video enter the BIOS (read up) and choose on - board video.
Try a graphics card (or on-board, or a different one known to work - see one of the many articles on how to set up a graphics card) Borrow one.
Essentially my course of action is try an alternative graphics facility to the one you have at the time of your post.
(Ihave just looked at the specification for this model at http://www.cnet.com/products/gateway-gm5420-core-2-duo-e6300-1-86-ghz-2-gb-320-gb/specs/
and it has on board Intel graphics default. Assuming the hasn't been an graphics 'upgrade' on your PC
You might find this webpage helpful (it has a troubleshooting section in the service manual)
http://us.gateway.com/gw/en/US/content/drivers-downloads
19.December.2014
May 28, 2014 | Gateway GM5420 Refurbished Intel Desktop...
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
I have Dell optiplex GX280..with 2 GB ram and 3.0 processor,,, i bought a 256mb 3D card and put into slots for the graphics in cpu.. but when i turend on my pc at 1st it runs towards to the starting of the...
It sounds like you may have forgotten to turn off the on-board video. If you insert a graphics card when you have been using the on-board graphics before, you need to go into setup ( on Dell it usually involves tapping the F2 button before Windows loads) and turn off the onboard graphics or windows may try to load 2 video drivers and fail
Sep 30, 2012 | Famous Brand Dell Optiplex GX280 Intel...
Apacer Micro Sd (adaptor) not read by computers.
well i would see if you have the updated drivers for the card reader.. if not it might be a older computer that is not savy with the new high tech stuff we have today.... i hope this helps.... let me know
Jul 31, 2009 | BFG Technologies GeForce 7800 GTX OC ,...
PSU and Mother board Damaged
You should be able to find stuff for that dell on ebay good luck Jonny
Mar 13, 2009 | Dell Dimension 8400 PC Desktop
No Video
Hi Keith, the Intel D845GVAD2 board uses an integrated graphics card for video & also uses your system memory to function.
Suggest, you remove the system memory & clean the contacts with alcohol. (Allow time for the alcohol to dry). Blow the memory slots out with canned air to remove any dust build up. Reseat your memory & boot the system. (No display)?
From your description it sounds like the integrated graphics controller may be bad. The only way to test this would be to add a PCI video card to the system.
The board’s bios uses auto detect. If you add a PCI graphics card to the system the bios should auto detect the PCI video card & load display.
There is a chance that the controller is too damaged & the bios will not see the PCI graphics add in card. In this case the board would be considered bad. If you have a local computer shop or know of someone who may (have a known to be good) PCI video card, you can ask to borrow it & test your system for video display.
Here is a link to an inexpensive PCI card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2174312&CatId=695
Intel's web site, downloads for the board D845GVAD2:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=898&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Good luck Keith!
Mike
Nov 30, 2008 | Intel Desktop Board D845GVAD2 Motherboard
Graphics card doesn't Install
sp3 always messing stuff up uninstall sp3 than install ur card
Nov 29, 2008 | Gateway GT5228 PC Desktop
Which specific harddrive components would you put into a home-assembled PC?
DUE you're going to work with graphics files you need a good HDD (capacity) 500 GB will be great
Memory at least 1GB and above
Processor 3.0 Ghhz and above
DVD Drive (any double layer)
Sound card (on board is enough), however you can improve later adding a new one, but you don't need that)
Good Graphics card (At least 256 MB)
Oct 07, 2008 | Computers & Internet
Kogie monitor
check your graphics cards settings in the bios.
set to AGP/IDE as appropriate.
use another monitor if necessary.
Also check the graphics card i.e on-board or PCI/AGP Cards functioning correctly.
Mike @ compurepair.
Feb 24, 2008 | Computers & Internet
ASUS A7S8X-MX Motherboard Logo
177 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
