Question about Cyberhome CH-DVD 300 DVD Player
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
I have two CyberHome CH_DVD 300 DVD. No light fuse is good unit(1) want power up and unit(2) red light but want do nothing either by front panel or remote, both are connected to AC power source.
  • 2 more comments
  • Anonymous Nov 25, 2007
    fuse is good no red or green light checked for out put voltage it wont maintain
  • Anonymous Nov 28, 2007
    Same problem as stated -- no indicator light. Checked power supply and +5 volts is sitting at about 2 volts. +12 appears to be ok.
  • Anonymous Mar 25, 2008
    I have a ch-dvd 300 dvd that when pluged in I have no power to the unit. I have checked the cord, and the fuse which were good, but I get no lights at all. As mentioned this was a problem with this unit..now I would like to know if it's worth fixing when a new one could be purchased maybe cheaper then It would cost to fix and shipping?? Please advise what you think I should do with the unit. Thanks GERRY
  • SLACKER1 Mar 26, 2008
    I HAVE A CYBERHOME DVD PORTABLE PLAYER (MP3) WANT COME ON AT ALL. WAS WORKING UNTIL SOMEONE UNPLUG BY THE CORD. HAS NOT WORK SINCE
  • 4 Answers
The CyberHome CH 300 is a good, inexpensive DVD player with a power supply board prone to fail, because of a few weak components, especially if left turned on and not used.
Usually, if the power supply fails, the red light will not illuminate when plugged in, and of course not turn green when turned on.
If you have this specific problem, I can repair the power supply for $20.00. Contact me at [email protected] to arrange shipping and return of the repaired board.
Posted on Nov 17, 2007
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Posted on Oct 12, 2007
SOURCE:
SOURCE: Remote Codes
i need remote code cyberhome ch dvd 300 for rca control
Posted on Dec 30, 2007
SOURCE: Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
I have the same problem, but I know what the cause is. Mine stopped working right after we had a power failure, so I suspected a power problem. The +5V DC supply from the power supply pcb is only at 3V. I removed the wires for the +5V and patched in a USB cable to provide +5V and it is now working fine. I noticed that one of the capacitors on the power supply pcb is buldging on the top, so it's probably bad. I'm going to try to replace it and see if it fixes the problem. The simple answer is that your power supply pcb is not working correctly.
Posted on May 18, 2008
SOURCE: disassemble CYBERHOME DVD CH 300
This guy has pictures and instructions for a major operation on a cyberhome player.
http://backandforthblog.com/?p=11
Posted on Mar 12, 2009
SOURCE: Reset Cyberhome CH-DVD 300
Dear friend,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Posted on Mar 25, 2009
SOURCE: I have a Cyberhome CH-DVD 300 DVD Player &
Toss this junk to the garbage can, this is how I solved my frustrations with my two units.
Posted on Dec 31, 2009
Dear friend,
Mar 09, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome player will not turn on--
I had the same problem, only the LED stayed light red/orange and nothing worked. With the unit unplugged, first try to manually eject the DVD by sliding the plastic tab in the slot on the bottom in the direction indicated by the arrow. Leave the tray extended and plug back in. Or, with the unit unplugged, press and hold the Eject button and then plug back in. If none of those work and the fuse is good, check this site: http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300
Mine had a low 5V supply. I did the change to the PC board as shown on this site and added a ~90K resistor from ZD2 to U3 and viola it fixed the problem!!
Mar 03, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
Red lıght on the front panel
No problem about pluging 110v ac if your dvd is auto volt from 100-230volt. when you plug your dvd press power button in your unit or in remote. if dosent any fucntion need a repairman tech.
Apr 01, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd ch-300 dvd player
Not sure, but I believe the 2.75 volts you have should be 5.0 volts.
May want to check capacitors on power supply.
The output connector on the supply may also be labeled with
the correct volatges for reference. COnstant orange light may be
indicating the +5v is low.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Red light is barley on
Sep 27, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVD 300 player
check the continuety of the power cord if its still good with no break, take the set to a tech for repairs the set has a problem in the power supply.however since walmart do not want to honor the warranty good luck.
Apr 11, 2007 | Cyberhome CH-DVD 300 DVD Player
Red light stays on when powered,won't turn on.
Don't have a solution. Cannot turn red lite off with remote or manual operation.
Oct 25, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
309 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
