Question about GE WBSR3140DW Top Load Washer
It only spins!
My washer spins only. The circuit board has been replaced. Previously, I've succeeded in getting it to function correctly by wiggling the dial.
  • 100 Answers
Your pressure switch my be bad. Does the washer fill with water and what does it do after that?
Posted on Oct 30, 2007
  • Mike Kaiser Oct 30, 2007
    Washer is not filling and stuck in final spin.
    CAUSE
    Washer cycle was stopped before
    completion and left in pause for longer
    than 24 hours. After 24 hours, an Automatic
    Feature pumps out all water to help protect
    against bacterial growth.
    SOLUTION
    Select a different cycle and disconnect
    power to washer for 30 seconds (reset
    controls). Instruct the consumer on cause
    and solution.
    CAUSE
    SOLUTION
    and solution.
SOURCE:
My kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Dec 03, 2014 | Kenmore Washing Machines
Water loads up but does not wash nor spin but does drain
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board he motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 09, 2014 | Maytag Neptune Washing Machines
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Model #417.41142000 Circuit board has been replaced to correct drum not spinning. Now timer won't advance.
are you Shure that the cable has not come off the spin pause button or from another part of the cable loom its worth checking eric
Dec 26, 2017 | Kenmore Washing Machines
I have a kenmore 110.46472501 front load machine. My problem is the drum not spinning at all/infrequently getting to top spin speed. In diagnostic mode, I only get F01 error(EEPROM). When in diagnostic, it...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 05, 2010 | Kenmore 46472 Front Load Washer
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Koss DVD
the humming noice is the dvd spinning trying to read the disc so we know that works take it apart and see if the laser is working d{dont look in the laser} and if that works take a q-tip and lightly wipe off the laser lightly move the laser up and down to make sure its not stuck and try to see if it works then
ps keep it off the carpit
Jan 22, 2008 | Koss KD250 DVD Player
GE WBSR3140DW Top Load Washer Logo
29 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
