HP PSC 2210 All-In-One InkJet Printer
Problem for HP PSC 2210 All-In-One InkJet Printer
HP Product Registration pop-up
By Constance on Oct 04, 2007
I can't seem to get rid of the HP Product registration pop-up. It pops on my screen dozens of times whem I an on the internet. I've tried clicking on register, and it closes. If I click cancel, I can choose when I want to see it. But even if I click to now show it to me again, it keeps coming back over and over. I just want to eliminate it.
Same Problem
May 26, 2009
-   Likewise, I am fed up with the constant pop ups for registration. Hundreds a day! Hope the solution works.-   Guest
Apr 17, 2009
-   i have the same problem. the registration pop up keeps coming up every 10mins. i have just tried dbaldwin's solution. i hope it works. thanks -   Guest
Mar 17, 2009
-   Registration Pop-Ups-   teamjackson2
Feb 15, 2009
-   I have the same problem with HP Product Registration, can you help me?-   Guest
Jan 11, 2009
-   Same problem with the 'extend my warranty', and nothing, I mean nothing works to get rid of it. I even clicked on tell me more/purchase and it only took me to the HP site, and still nothing to disable the pop up. I am no longer going to purchase HP computers again.-   Guest
Best Solution
posted on Sep 16, 2008
Very Helpful)
dbaldwin
Rank: Apprentice
Rating: 97%, 31 votes
This is caused by an entry in the Task Scheduler. To get rid of it, you need to be logged on with Administrator priveleges, then do the following:
1. Click Start, type the following in the search field and press enter: Task Scheduler
2. Cllick Continue to confirm permission.
3. Click Task Scheduler Library in the Left column.
4. Click on any of the following in the center column:
a. InternetService Offers (If your pop-up is regarding the internet)
b. Registration (If your pop-up is regarding registering your PC)
c. Service Plan (If your pop-up is regarding warrenty)
d. Extended Service (If your pop-up is regarding extended service plans)
BTW, notice that the idiot that programed these entries set them to trigger every 30 minutes, indefinatly.
Hope this helps.
Dave
Was this helpful?
Yes
No
21 people thought this was helpful
Solution #2
posted on Oct 14, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I contacted the online help at HP for the same problem with a different printer.  This is a copy of the log.  Good luck.  Hope it helps us both.
 It says it is HP Product Registration and that I need to go online to register. Right now there are 36 of these on my computer
HP: Yes, I have a probable solution which will resolve the issue.
May I know, What version of Windows are you using (Windows 98, Me, NT or XP)?
Me: XP
HP: Please click on the Start >> All Programs >> Accesories >> System tools.
 You will have an option of scheduled tasks in that.
Please open it and delete all the files related to HP.
Me: It had a HP usg daily in it and I deleted that
HP: Okay, now please click on the Start >> run.
Type as msconfig in it and click on OK.
HP: Click the Startup tab.
 roam the list, deselect all the HP programs. Click OK.
After that you need to restart the computer. This will resolve the issue.
Solution #3
posted on Apr 26, 2008
Helpful)
SENHAR
Rank: Apprentice
Rating: 84%, 3 votes
INSTEAD OF DELETING, I MERELY CHANGED THE SETTING FROM "DAILY" TO "ONCE" .
Was this helpful?
Yes
No
Solution #4
posted on Oct 12, 2007
Helpful)
DATA80211
Rank: Guide
Rating: 79%, 37 votes
Have you registered the product? I know it seems like a simple question but most people skip the registration of the product.Try going on the sight and register.Sometimes the produscts company recognizes this after you register from the sight and it goeas away. Or uninstal the device and reinstall and try to register
Was this helpful?
Yes
No
Solution #5
posted on Nov 13, 2008
Somewhat Helpful)
sarcatmac
Rank: Apprentice
Rating: 75%, 1 votes
I purchased my latop over a year ago and I am still receiving a pop up prompting me to purchase an extended service warranty plan. No matter which option I choose the window continues to show up! How do I get rid of this issue?
Was this helpful?
Yes
No
Popular Solutions for HP PSC 2210 All-In-One InkJet
Questions and Unsolved Problems for HP PSC 2210 All-In-One InkJet
Do you recommend HP PSC 2210 All-In-One InkJet Printer?
Answer
Answer
displays - "enter to align cartridge" constantly, won't get out of that mode. Therefore... (More)
Answer
printer will not align when enter button is pushed. "paper mismatch" shows in display.all... (More)
Answer
How do I find the estimated ink level in the cartridges on a HP psc 2410xi photosmart running in... (More)
Answer
hp 1200 series blinking problem with cartridges
12 Other Users Have The Same Problem - Continued
Comment by janetdb, posted on Jul 13, 2008
I had the same problem with the HP Product Registration pop-up that was multiplying itself. I went through the steps that were posted in the first solution here and then restarted my computer. A screen came up titled System Configuration Utility. It suggested that I choose Normal Setup to start normally and undo the changes. I didn't think that sounded like a good idea so I did not do that. There was also a box to check that said Don't show this message or launch the SCU. I did not check the box. Should I check it if it comes up again?
Comment by Guest, posted on Jul 01, 2008
I can't get the HP pop up to stop coming up when I'm on the internet. Any suggestions?
Comment by Mcoffee1, posted on Jun 07, 2008
I have exactly the same problem where the product registration keeps poping up and if you try to register or say 'dont show me again' or try to close via task manager it keeps coming back until you have some many pops runing it stalls the PC
Comment by Guest, posted on Jun 02, 2008
exactly the same - I may get rid of my HP
Comment by Guest, posted on Apr 26, 2008
I have the same problem.It is extremely annoying.Since others have the same problem it is about time that HP solved it since the only beneficiary of the registration request is HP itself.
Comment by Guest, posted on Apr 25, 2008
constant pop ups on my computer sometimes as may as 20 at a time
really slowing it down
Comment by nevpin, posted on Jan 07, 2008
I constantly get the HP product registration popping up. No matter what I do it does not go away.Instead it seems to replicate itself several times and closing out the boxez becomes a tedious task
HELP
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
