Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Mainboard OC Failure
By Theruby on Oct 04, 2007
Hello. I have a problem with overclocking. My mainboard is MSI 945P Platinum. When I try to overclock it to more than 3.3 GHz, it doesn't start and even there's no beeping. What can I do with it?
What I've done: updated bios, tried to change ram timings but there was the problem that it didn't start and there was continuous beeping, so now I have it By SPD, installed latest chipset drivers, changed memory freq. to the lower one, but nothing from this worked for me.
Processor: Intel Pentium 4 3.0 GHz, Prescott
RAM: A-DATA 2x512MB 333 MHz DDRII
I am not sure if this is caused by my RAM or mainboard, but I guess it's by mainboard.
Comments:
Oct 06, 2007
- After your reply, I tried to do these things you posted, but nothing from this worked. I tried to low the ram freq., but when I did it, my PC didn't start, so I had to keep it. The next thing was the voltages, I set it higher but it didn't work also. I think it isn't caused by cooling because the computer would start although it hadn't got any cooling.
Maybe I am maxing out the power supply, but I don't want to invest if I am not sure what it is caused by. I cannot lower the multiplier because it is a fixed number that I can't change (15).
What can I do to find out what it is caused by?
Oct 06, 2007
- So, which RAM do you think will be a great investment?
Apacer DDR2 2x 1GB 800MHz GOLDEN KIT
or A-DATA DDR2 2x 1GB 800+MHz dual Extreme Edition
or CORSAIR DDR2 2x1024MB 800MHz TWIN2X
Oct 07, 2007
- I've just found out that my motherboard doesn't support 800MHz RAMs, it supports just 667/533/400. But I have 667MHz so I don't know where the problem can be. I tried to low the frequency and to high the FSB, but it didn't work. Maybe there's the problem that my power supply cannot handle it. I have 400W. I will focus on this.
Oct 07, 2007
- Just wanted to ask if the power supply cannot handle it, how can I recognize it? When I set the frequency too high, my PC starts, but monitor is black and there's no beeping. May this be caused by power supply? (I mean if the PC can behave like this if it's caused by power supply)
Best Solution
posted on Oct 04, 2007
Very Helpful)
PCTServices
Rank: Guru
Rating: 86%, 390 votes
Odds are it's a combination of things. Any of the things listed below are most likely adding to your crashing
-You're ram is probably operating at it's max threshold.
-You may not have good enough cooling on the processor / ram.
-Your processor may need higher voltage to handle that large an increase in clock speed
-You ram also may need an increase in voltage
-Both of those above are dangerous btw
-Your motherboards south bridge may not be able to handle that much power
-depending on the specs of your system you may be maxing out your power supply
-you may be running too high of a fsb for the ram / motherboard to handle
-You may need to lower the multiplier to raise the fsb more or vice versa
First and formost though, cooling and voltage are going to be the key in extreme overclocking, which is what you are doing by raising the clock so much.
You need to read up on voltages related to overclocking the processor and ram and become an expert on the subject. Only once you understand the reasons why it works and how dangerous it can be to your hardware should to go any further. You also need to keep in mind your cooling setup. FSB overclocking overclockes all the of the other parts of the system too, not just the CPU, so multiple cooling fans that eliminate dead zones and target certain parts are a must. Make sure your processors heatink and fan are more than ok, in fact, you may want to consider some type or liquid, cryo, or heatpipe technology if you aren't already using them.
Like I said, you may need a larger power supply too, or maybe some stronger ram. You could try raising the rams cas latency. raising it by .5 may make the system bootable, or even stable. But this also will slow down the system, so you have to way to pros and cons and see how much higher you can go and if it's worth losing ram latency.
300mhz is a pretty large overclock, personally I'd be happy with that unless I was ready to invest in the parts and time needed to push the system past a 10% overclock.
Remember though, as good as an overclock you get on the system you still need a software tune as well. Even the fastest systems can get bogged down by an untuned windows. If you're not already, learn everything there is to know about tuning windows services and explorer.exe as well as registry tweaks.
You can literally cut a windows install down to half of the ram footprint as a default install and make it use very little processing power on the backend.
If you have any further questions post them here and I will do my best to reply back.
I hope this has explained your question in detail. If I've helped you please don't forget to rate me.
Peter
Comments:
Oct 06, 2007
- If you're not changing the multiplier due to it being locked then you're just fsb overclocking. That is your problem. You're maxing out either your ram, or your motherboard. Odds are you need overclocking specific ram. They make ram that is capable of running higher than industry standard speeds, you'll need that to make any more progress probably.
Personally I'd be pretty happy with a 300mhz increase, thats 10% when you get down to crunching numbers. Some people only manage 5% overclocks.
Like I said, to get any further with this overclock you need to make investements. Better ram would be my first suggestion, then maybe a better power supply after. Something in the 500 - 600watt range will do just fine.
Oct 06, 2007
- I would probably go with the corsair
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
free dell oplitex gx280 multimedia audio controller
Answer
need bios reset pins for k7t turbo n1996
Answer
i need to know how i connect the wires of hdd led, power sw,etc to my motherboard
Answer
heat trip switch melted
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14802
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
