SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
SOURCE: LG french door refrigerator ice maker
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
