Question about Epson Perfection 1670 Flatbed Scanner
Epsonperfection 1670 fluorescent light replacement
I am having trouble receiving an image after scanning my document or photo. The scanner is able to scan but no image appears. I have downloaded the "epson TWAIN 1134", am operating Windows XP, uninstalled, disconnected and re-installed as per your website suggestions and still no results. Could it be the flourescent light withing the scanner that needs replacing and if so, is it worth the cost. Thank-you for any suggestions. charsweb
  • 8 more comments
  • Anonymous Nov 06, 2007
    I have exactly the same problem. I'm running Windows XP and have installed the new driver. Stll no image although all seems to be working fine.
  • Anonymous Nov 12, 2007
    Scanner scans but says "Cannot find document". Flourescent lamp is working. Suspect a CCD board.
  • evee Nov 14, 2007
    We have the same problem - Epson 1670 goes through the motions, and an image file is created but it is empty white space. Have tried from Epson scan program and from within Photoshop.
    Uninstalled / reinstalled software and hardware, tried different usb cable, tried differed usb port
  • Anonymous Nov 17, 2007
    Appears to scan properly but just a white page results, whether using the scan-to-printer function or from PS Elements.
  • rdb3 Nov 17, 2007
    Same here -- it goes through the motions, but results in only a white sheet, whether going straight to the printer or into PS Elements. Light is on.
  • Anonymous Nov 29, 2007
    I also have a Epson 1670 that decided to quit scanning recently. It goes thru the motions but no image appears. I just tried unplugging it as per some posting suggestions and will give it a day or two off and see if it wants to work after that.
  • Anonymous Jan 25, 2008
    it was working with windows 2000 but now not working with windows XP
  • Anonymous Jun 12, 2008
    I have uninstalled and installed the software, the scan seems to be operating, but the computer does not receognize or show any picture.
  • Anonymous Jun 27, 2008
    We seem to have the same problem with our Epson 1670. Last week it just stopped working. It goes through all the motions like it is working, but there is no image. it will not work for photos, slides or negatives, nor will it work to make a copy of anything. The light inside seems to be fine. I uninstalled and re-installed scanner and software, but still doesn't work. Maybe they just wear out after a lot of use, and it might be cost prohibitive to repair.
  • Anonymous Aug 02, 2008
    The problem is the same as others have described: Scanner arm moves, with light, but no image appears. The light, while bright, is not leaking out from under the lid as it used to do. I use XP and have installed most recent driver, rebooted, etc., with no success. Have used this scanner a lot for more than four years with no problems.
Hi! I had to go to the Epson site and download the VISTA fix so my scanner would work. My suggestion for any new downloads is that you DISABLE ALL and I mean ALL of your antivirus programs first. With Vista, I have three antivirus programs running.
Then install the new download. Believe me this works. Something in the antivirus programs prevents the download to work properly. Restart your computer. Plug in your scanner, then the USB. Don't forget to activate the antivirus programs when you're done! Hope this helps someone!!!
Posted on Jul 27, 2008
  • 3 Answers
Here's what Epson tech support sent me about this problem:
Thank you for contacting the Epson Connection.
The error you are receiving may be from the twain driver but also the
Scanner itself. Please have your scanner checked with a technician. You
find the neares one by clicking on the link below.
If you require further assistance with this particular issue, please
all of our previous correspondence is contained in your reply, so we
better track the history of this issue.
If you have a different issue, please submit another E-form via our
(, and we will respond in a timely manner. Thank
again for contacting Epson.
Patrick H
Epson Connection
Posted on Jan 19, 2008
The scanner light on my epson 1670 fluctuates in intensity during scans which produce darker bands across printouts
check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Oct 06, 2010 | Epson Perfection 1670 Flatbed Scanner
I unplugged my epson perfection 1670 scanner because my my mac said it was not connected--now when I scan something there is no image--just some lines--how do I correct this?
try uninstalling the drivers and then reinstalling them if it doesn't work you will need to replace the lamp in your scanner for information onthis go
Jul 13, 2010 | Epson Perfection 1670 Flatbed Scanner
My Dell 948 printer produces a thick black line on documents
Leave the cover up and run a 'copy.' Look closely at the fluorescent scanner light and note if it seems equally bright from end to end.
If it does, the photo-assembly that acts as an image receiver is probably sick.
If it is, with the labor cost and potential non-availability of parts, you might be better off replacing it unless still under warranty.
Jul 02, 2010 | Dell 948 All-In-One InkJet Printer
The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
Scanner is not detecting images / photos to scan resulting in a blank preview
The image sensor may have gone bad. Try reinstalling the driver, if it does not work... It is time to get a new one (it is more expensive fixing a scanner than buying it brand new). Sorry. Good luck.
Jan 03, 2010 | Epson Perfection 1670 Flatbed Scanner
I keep getting an error that reads "unable to write to file". It was working fine and now I get that error about every 3rd scan.This is on an Epson Perfection 1670 scanner.
Just check if you have enough space where you are directing the scanning software to save the scanned images. You may be running short of disc space.
S. Mohan
Nov 04, 2009 | Epson Perfection 1670 Flatbed Scanner
WHEN PHOTO IS PLACED IN IT SCANS THEN SAYS THERE WAS NO DOCUMENT THEREalso tried to uninstall to reinstall and it will not let me
did you remove the document matt inside the TPU? when you try to uninstall pls try to unistall using the add remove programs located inside your control panel
Sep 06, 2009 | Epson Perfection 1670 Flatbed Scanner
Computer says there is no document on scanner
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Jan 26, 2009 | Epson Perfection 1670 Flatbed Scanner
1670 no image scan
Same Problem (WinXP System). I found leaving it off when not using it fixes my problems. (Its like the scanner light overheats or overloads the light receptors and it just sees white from then on, no matter what you do on the pc side of things). Other problems while stumbling into this "fix" include WIA drivers loaded which will stop scanner working properly, and finally scanner drivers seemingly working when USB cable in connected to another port other than what it was installed on but no image is shown (Not 100% sure if it was same problem as detailed at top)
Feb 08, 2008 | Epson Perfection 1670 Flatbed Scanner
Epson Perfection 1670 Flatbed Scanner Logo
590 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
