Question about Sony SDM-HX73 17" Flat Panel LCD Monitor
17 Monitor turns black while on. I will hit the power on/off on the monitor, then the screen resumes
  • 3 more comments
  • squawla7 Dec 24, 2007
    screen black ,,,turn on & it stays on for 2 seconds then goes black again
  • Anonymous Jan 20, 2008
    Same thing stays on fro 2 secs and then black
  • merggg Feb 24, 2008
    my monitor also turns black while on. if I too, turn it off and back on the screen resumes. this occurs very randomly, it can be on for hours without any blank screen, but it can also mulfunction 3-4 times in an hour! all started 3-4 days back... the only thing I remember weeks ago is that when someday I turned on the monitor I noticed some red thin horizondal lines across the screen along with "vibrating" and distorted display, but seconds later everything went back to normal. the monitor worked perfectly until now.
  • daimos35 Oct 01, 2008
    Monitor powers on but screen is black. When I press the input button on the right side of the monitor, the picture appears for a second or two and then disappears.
  • tonmorris May 07, 2009
    Same problem with my unit it will not stay on but for a minute. I hooked up another monitor and it works fine. Any Ideas ?
Same thing with my computer
Posted on Oct 28, 2008
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
May 24, 2009 | ViewSonic VA721 17" LCD Monitor
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
Sony SDM-HX73 17" Flat Panel LCD Monitor Logo
174 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
