Question about Sony Ericsson K610i Cellular Phone
K610i Hey, The other night my phone battery dide so naturally I tried charging it only to find that nothing was happening bar the red light at the top keeps flashing. Sometimes it flashes erratically and sometimes it stays on for a continuous period. Ive cleaned the pins both on charger and on the phone itself to no avail. I brought it in to a several shops and they all tried to charge it...no joy. I have alot of stuff on the phone memory that I really neeed to get. Any ideas? Thanks
  • pride34 Dec 04, 2007
    the keeps showing that battery low i have put it on charger to no avail. i bought a new charger still nothing is happening help
I have the same problem.
My opinion is that you have to flashing your phone. I'm still looking for good program to resolve this.
cheeer
Posted on Oct 20, 2007
SOURCE:
Sony Ericsson K610i does not working...while am trying to switch on...the red light blinking
the battery might already be empty. try charging it for 10 minutes or longer before switching it on.
Oct 06, 2009 | Sony Ericsson K610i Cellular Phone
K610i phone blinking red light 5 times after i replace another sim
If it blinks red light 5 times, it means the battery is completely empty and you have to charge the phone...The charge is completely dry.Try charging for some time, and try switching the phone ON
RNJ VINOD KUMAR
Sep 20, 2009 | Ericsson Cell Phones
Flashing red light
it is a software problem get a new phone you can't fix this problem sorry hope I helped
Aug 31, 2009 | Sony Ericsson K610i Cellular Phone
I am from india. i am using sony ericson k610i brought from u.k . initially it was locked with 3 mobile network of uk. i unlocked it here by local mobile shop. it was workink smoothly....
software reset.. download the update software update off the sony ericsson website... install it... all you need is a usb cable. i just fixed my brothers phone.. using the software update. it was doing the same thing... hope that helps ... BEWARE THOUGH IT WILL RESET YOUR PHONE meaning all your contacts and anything not on your sim and memory card will be deleted
Aug 22, 2009 | Sony Ericsson K610i Cellular Phone
My K610i won't turn on. Red light flashes n won't charge.
HI,
That indicates a problem with the battery.Try a reset first.
Connect the phone to the power adapter and then press and hold the power button for more then 1 min.If it still doesn't turn on then remove the battery and sim from the back and then insert the sim back again and hold the power key for more then a min.Make sure you don't insert the battery now.Let me know the result.
Thank you
Aug 02, 2009 | Sony Ericsson K610i Cellular Phone
K610i
Got that same problem before with my sony handset. It may be a virus or a software problem.
Basic troubleshooting steps.
1. Remove battery for 5 mins insert and turn on. Make sure battery is not empty.
2. Run a virus scan on your phone.
if nothing happens just bring it to a nearest repair store. Still under warranty period? also bring it with you reciept to a nearest Sony Repair Store.
May 20, 2009 | Sony Ericsson K610i Cellular Phone
K610i power cannot turn on but only red blinking light at the top
try this website for solution.. http://www.akshayy.com/sonyericsson/tutorials/red-light-blinking-dead-revive-it-to-life/
Dec 09, 2008 | Sony Ericsson K610i Cellular Phone
Dead phone
Hi, Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson Update Service) which is free and if that doesn't work then you will need to use wotanserver(requires credits=money) or send it to a service center. Good luck!
Dec 12, 2007 | Sony Ericsson K610i Cellular Phone
Battery light
This is pretty common and not necessarily a problem. Red means that the battery is not completely charged. Since it was charging all night, it most likely almost fully charged - say 99% or so. It's not really an issue as long as your battery icon has all the bars and the phone holds the charge for a normal amount of time. If you find that the charge lasts for less time than it should, you should probably replace the battery. My phone, for example, does this every so often and then will charge normally the next day.
Dec 05, 2007 | Motorola Mobility RAZR V3
Wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Jul 23, 2007 | Sony Ericsson K610i Cellular Phone
Sony Ericsson K610i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
