Question about Abit KV-85 Motherboard
Purchased Used Just purchased a used mb which as u might have guessed didn't come with an installation CD. Where might I be able to get that info and burn to a disk
    Guru:
  • 120 Answers
You can find the drivers needed for your motherboard here. http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=4&category=3&subcategory=219&model=305&product_name=KV-85 Download everything listed on the page. You can burn it to a disc on a windows xp computer by right clicking on the files and selecting send to, then your cd burner. I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Posted on Oct 04, 2007
What size sd card needed for digimax A402 samsung? I purchased an 8gb and card read error? Do i need a 2gb? I purchased camera used and don't know what size sd card it uses???? U can email ans
Your camera has 16 MB of internal storage and will accept up to 516 MB of external storage. It will not accept anything greater than an 516 MB card. 8GB is too large and the camera will not recognize it.
Buy a 516MB or smaller card and try it, they are very inexpensive.
Sep 26, 2014 | Cameras
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
Speedometerworks, but odometer/tripmeter stopped
The odometer/trip meter work together via a IC and pulse motor. I just replaced the Instrument cluster in my 94 Corolla DX. I purchased a used cluster that had 230,000 miles showing( mine was 199,000). It' a "plug and play" system, electronic analog. The cluster I purchased the trip meter didn't function, I removed the speedometer from the cluster and applied some silicone spray to the plastic gears and now it's working, (the plastic gears are very fragile and after many miles and years they are prone to breakage). If you are lucky this might be a solution, If not buy a used instrument cluster and install it yourself and hope for the best (used). I didn't have a tachometer on my original cluster so I purchased a cluster with a Tach. The 94 DX and LE should be "plug and play",not sure about the CE. The change is quite simple tow screws remove the bezel, 4 screws remove the cluster, unpluy the connectors, 2 white 1 blue.The cluster was $55.00
May 17, 2012 | 1994 Toyota Corolla
Just purchased a cub cadet 1610 Hydro. How do I determine the year it was buit off serial number? Or a site i can go to to find out?
I am guessing this machine was purchased used. If so take the number off your machine and go to your local Cub Cadet dealer. They should be able to give you the information you need ,plus other info reference, parts, service, etc. GOOD LUCK.
Jun 16, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I used the one on the disc, but it says invalid.
I'm assuming you're talking about the CD key you got with your operating system. If the seal wasn't broken when you purchased it, and the CD-key still didn't work, you can return the complete package to the retailer where you purchased it for an exchange or an in-store credit. But keep in mind that a lot of stores have no-refund policies for computer software with open packaging.
May 02, 2011 | Computers & Internet
I purchased AVG but it didn't install properly so I cancelled the installation. Now how did I install the product I've already purchased? I have the license number.
Most probably it seems to be a low ram problem but you should match the specifications with your machine to find the culprit.
here are the specifications
Processor Intel Pentium 1.5 GHz Memory 512 MB RAM Hard disk free space (for installation) 750 MB HDD Recommended system requirements
Processor Intel Pentium 1.8 GHz Memory 512 MB RAM Hard disk free space (for installation) 1200 MB HDDI guess you lack something among them please verify them .
If you re still not able to resolve just comment with error message
Jan 18, 2011 | Computers & Internet
My IBM Thinkpad T23 needs a set up disc. I purchased it used so do not have one. Help
Use a Windows installation CD, and you will need the product installation code. This code is printed on the Windows label on the bottom of the laptop. Make sure the Windows CD matches the Windows version that is printed on the label.
May 20, 2009 | IBM ThinkPad T23 2647 Notebook
I CANNOT FORMAT AND INSTALL A NEW OS
You RAM module may be faulty or needs reseating in the DIMM slot B. Reseat the both RAM modules then :-
Check the POST information as it boots up, the amount of install RAM should equal to the installed RAM (the total RAM could be 256Mb or 512Mb or 1Gb depends how much memory you purchased with the laptop) less 64 Mb or 128 Mb RAM which is used for video memory (depends upon your video card requirements).
Once you fix your RAM problems you should be able to reinstall Windows.
Mar 04, 2009 | Dell Inspiron 1525 Notebook
Purchased CD Garmin Map Update 2009 to update map in my Streetpilot c330. Drver will not install. Troubleshoot info says problem between smart card and windows on my PC. I have windows vista. Set uo...
You need to contact Garmin, and find out if this update CD will work with Vista, some do not if they where made before the driver on the cd was designed for Vista, the update cd that I just used would not, thus I did it on an XP pro system. And it worked ok
Jan 13, 2009 | Garmin GPS
Transcend t sonic 610 2 gb player is not getting format
when you purchased the t sonic mp3 player 610 box pack at that time or in that box one CD is there. put that CD in CD ROM and install recovery. then in recovery or where the recovery is install go there and select firmware update, when we update the firmware virsion at that time the data will be loss.during the update don't disconnect the drive.
Apr 21, 2008 | Transcend T.sonic 610 MP3 Player
Abit KV-85 Motherboard Logo
59 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Daniel Dollive
Daniel Dollive
Mike
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
