Mitsubishi TV My older model 35" tube mitsubishi tv becomes blank in the middle of the screen after a few seconds almost like there is another screen popping up in the middle of the larger screen. There is about a 2" border around it where I can see the picture behind it and it is okay in that border. It goes away for a few seconds when I change channels but then comes right back. It does it on any input cable or DVD?
  • Anonymous Mar 08, 2008
    need tv back on channel for cable service and have no remote for tv
On the remote control,scroll on the video up/down buttons (either one) until you see CC. Next, scroll on the adjust up/down buttons (either one) until you have the CC option you wish to choose.
Posted on Apr 19, 2009
I have an older model vs4003r television. It is older I know but has barely been used. It was given to me a couple of years ago and works like new except......... The set somehow got umplugged and now I am locked out of the imputs and cant get in. The people who owned the set before have passed away and I have no working remote for it. How do I disable the imput locks on the set?
Posted on Jan 01, 2008
    Genius:
  • 1,694 Answers
What you are seeing is called a text box.As Techman indicated,
this function is controlled by closed caption choice.If you cycle
through the cc choices,you will find you are on "text".Set to off
or cc2 or 3, if there is no "off".Experiment with how to activate cc functions and you will then discover how to disable cc and/or text.  Please give rating to techman.
Posted on Oct 11, 2007
    President:
  • 3,130 Answers
Someone turned on the closed caption my friend. You will have to turn it off with the remote most likely. Since you thought we are fortune tellers and did not leave a model number, we cannot instruct you on how this is done. Most likely there will be a button on the remote that says captions or CC. Good Luck
Posted on Oct 05, 2007
My tv goes blank with sound only.
tough call. from your decription it could be the tubes the pulsating. but if i had it in the shop i wwould first look at the convergence curcuit. the fact that the on screen display come up in colors inidcates convergence problems. you might have multiple component falure there. as for cost it could be diddicult to say. average repairs like this barring piture tube problem at my shop run 200 labor and about 150 parts. this is just for convergence cuircit rpair
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV is blank and status light is blinking yellow
I think you have a powersupply problem. This model has had alot of problems with bad electrolitic capasitors through out the entire chassi assy. Because of the way the manufacture designed this unit you may be better off getting a Mitsubishi Authorised service company to fix it. If you feel confedent,
check the powersuppy for 2 electrolitic capasitors that are bulging on the top. They will be your culpirts. I believe they will be 25v 2500uf. But don't hold me to it.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
1993 tube 37" mitsubishi
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Feb 11, 2008 | Mitsubishi CS-35505 35" TV
Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Jan 02, 2008 | Mitsubishi CS-35707 35" TV
Mitsubishi WS-55311 flashing screen
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
Oct 21, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
