We have fiqured out that the cleaning web needs to be changed therefore
we have successfully done this but the error code E005 still appears.
Comments:
Dec 10, 2007
- I have put out the cleaning web to be change therefore I have successfully done this but the ERROR code E005 still appears. I have tried the *28* code to try to get into the service mode but does not. please help me first thank you.
hui im jules_09.canon error code can be reset reset it in the program if error code still apears youl have to re install the cleaning wed again then check if you followed the right process
to enter into setup press *28* i.e. press 2 & 8 at one time and go to copier then function then select IP and press ok and switch machine off and on and you have done.
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to...
(More)
canon m32043 microfiche reader and printer 90 has just stopped printing. It starts but then seems to jam - I am sure it not a paper jam as the code doesnt come up. Any ideas
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
