Question about Grundig YB 400PE AM/FM/SW Radio
Buttons Don't Work
I was having problems with my YB so I pressed the Reset switch. I am not sure that did anything other than wipe out my memories, but I have several buttons that don not function properly or at all. * The Power button does not work at all. The only way I can turn the radio on is to use the Sleep function. * The Forward memory button does not work. I can only scroll through memories in the backwards direction. * The 4, 5, and 6 buttons do not function properly. They enter 1, 2, and 3 respectively. All of the other number buttons input the correct numbers. Is there anything I can do to get this radio working properly or does it need factory service, which I am assuming would be prohibitively expensive?
  • Anonymous Jan 09, 2008
    the only button that works on my model  yb 300pe is the light button. I have replaced batteries with one that I know are good. nothing else works.
I would strongly lean towards factory service. Sounds like the circuit board has problems.
Good luck.
Posted on Dec 15, 2007
I need to know how to move past the WiFi set up page after a factory reset RCA galileo
Maybe something here:
1. Try and restart the tablet. Sometimes it is that simple.
2. Update the firmware and any apps that need updating on the tablet.
3. If the problem persists, check your time and date on the tablet to make sure it is correct.
4. Should none of the former work...
a. Clear out the WiFi data on the tablet.
b. Reboot the modem/router.
c. Once the modem/router is fully 'up' again, reboot the tablet and re-input the WiFi data.
5. Now, if you are still having the problem at this point, and you are sure it isn't the modem/router that is the problem. Then you may wish to try a "Hard Reset" of the device. However, I really suggest saving this as a last option (or last before parts repair/replacement) as it will wipe all your data off the tablet.
NOTE: Doing this will clear 'all' the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the device.
Be sure you back up any data you want to keep, to a computer or cloud account, before doing the reset.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Mar 29, 2018 | The Computers & Internet
Hard reset my password blocked Samsung xe700t1a
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the device.
Mar 26, 2018 | Samsung Cell Phones
How do I do factory reset on nextbook model NX17A8116R
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
Feb 25, 2018 | Nextbook Tablets & eReaders
Where is the reset button on my RCA Cambio 2-in 1 notebook/tablet
Jan 25, 2018 | Tablets & eReaders
How to reset a nextbook i found
Sep 25, 2017 | Nextbook Tablets & eReaders
My son forgot the code of his samsung omnia hd i8910 1 want to reset the settings but i cant because of that code
    • Open the telep *2767*3855# - Factory reset hone dialler by pressing the software button on the bottom left of the front screen.
    • Type *#7370#
    • You'll be asked if you want to restore all of the original settings and warned that the phone will restart. Choose yes.
    • Now you'll be asked to enter the lock code. Enter 00000000 as the code. That's eight zeros.
    • Click the OK button and the phone will reset. This takes some time so be patient.
    Occasionally you'll find yourself in a situation where you can't use the screen and therefore can't use this process to reformat a phone. In that case you'll need to do the following.
    • Pull the battery to make sure it's powered off correctly then replace it.
    • Hold down the green call button and the middle button at the same time.
    • With those two buttons held down, press the red power on button.
    • The phone should give you the option to format now and you can press the green key to accept it.
    Be aware that the phone memory and the hard drive will all be wiped clean so back up anything you need to keep either to a PC or to a memory card. Don't forget to remove the memory card before the reset as some memory cards may also be occasionally wiped in this process.
Aug 29, 2012 | Samsung OmniaHD i8910 Smartphone
I use nokia 5800...my phone got locked by fsecure ....i do not remember my password...how do i unlock it...plz help its urgent
Press green + red + multimedia button and turn the phone on at the same time. Wait until the "NOKIA" logo appears. This will wipe your phone memory.
If that doesn't work try this.
Soft reset/reformat - Type *#7370# and the phone's lock code (Nokia default lock code is 12345). Warning!Soft reset wipes the C drive/phone memory!
Hard reset - Switch the phone off. Press and hold three keys together, the green key, the * key and the number '3'. While you are holding these keys, switch the phone on. Don't release these three keys before you see the NOKIA logo.
Warning! Hard reset wipes the C (phone memory) drive.
Feb 28, 2011 | F-Secure Anti-virus Client Security...
How do i reformat my 6303 classic? It always hung everytime i useD it? So i hope you help me to fix it.tnx godblesS
There are two ways to reformat your phone. One is soft reset and the other one is hard reset. Soft reset resets the phone and quick format the phone memory. Hard reset completely wipes the phone memory and automatically reinstall the phone's firmware. So if your phone has a many problems, i would recommend doing a hard reset.
To hard reset the phone, switch off your phone. Then press and hold "green call key, * and 3" together and switch on your mobile. Don't release these three buttons untill you see the nokia hand shake. After that release the buttons and your phone is reset.
To soft reset. Dial *#7370#. Then enter the security code (default is 12345). That's all.
Hope it helps. Please rate the answer. Thanks for using FixYa.
Aug 26, 2010 | Cell Phones
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
How to format the Nokia 3500 memory card?
hi there,
here are some instruction you can follow to format you memory card
For soft format
*#7370# or *#7780# Reset your phone to the default factory settings. Usually you will need this code when you want to reset your phone back to the same condition when you got it for the first time. When the phone ask for security code, the default one is 12345.
Warning: Before you do reset the phone, make sure that you don’t have important data. Your data on the phone memory will be lost once you reset it.
For full format
Use the three button combination. Switch off the phone. then press the three buttons (green button, * , 3) and switch on the phone. the phone will switch on and display formatting on the screen. you van then let go of the buttons and wait for the format to finish. Make sure your battery is fully charged or the charger is connected.
Note: Better to go Nokia Service Center rather trying yourself as trying those means you are taking risks.
Feb 12, 2009 | Nokia Cell Phones
Grundig YB 400PE AM/FM/SW Radio Logo
215 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
