Cars & Trucks Logo
A
Anonymous Posted on Nov 09, 2013
Vt holden commodore brake lights dont work - Cars & Trucks
Terrence Dowd
Level 2:
Habit-Forming:
  • Expert 111 Answers
  • Posted on Jan 12, 2015
Terrence Dowd
Expert
Level 2:
Habit-Forming:
Answers
111
Questions
0
Helped
44968
Points
159
There could be a couple of reason why your brake lights are not working these are all common faults.
1.first remove the brake lens and check globes.
2.Next check the globe socket as they tend to get hot and the plastic housing brakes away so the globes don't connect.
3.get a test light and check for power.
4.if everything is ok then I would be replacing the brake light switch under the dash that makes contact with brake pedal.
good luck
5 Related Answers
Anonymous
  • 44 Answers
  • Posted on Jun 28, 2009
SOURCE: Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
Anonymous
  • 136 Answers
  • Posted on Jun 21, 2010
SOURCE: holden VN Commodore 91 automatic not reversing!!!!!
is it an auto or manual? if its auto the selector band may be too loose or gone completely, check fluid levels and make sure they are good as that can cause it to play up, a service may help free it of clogged and cluttered debree.
Anonymous
  • 2382 Answers
  • Posted on Feb 21, 2011
SOURCE: how to replace head gasket
Hi, replacing a head gasket is not a DIY job, unless the person has plenty of experience, knowledge, and the proper tools. The fact that a person would even ask, "How to replace a head gasket", would indicate to some that they should not trying to do that repair. To replace a head gasket you must remove the intake manifold, exhaust manifold, valve train, and then the head. This is very involved and requires disconnecting lots of sensors and the ignition system. The head must then be checked to see if it is warped, or cracked, and repaired if necessary. You must then know how to put all this back together and torque all the bolts in the proper sequence. This takes training and skill which the average shade tree mechanic does not have.
Pick up a Haynes or Chilton manual. Either one should give you detailed directions with illustrations.
Or let a mechanic do it...
smhb1
AbdulSamad AL Balushi
  • 146 Answers
  • Posted on Jun 20, 2011
SOURCE: How do you fix a
seatbelt should be replace for saftey might one of the small spring having problem
Sean80000
Sean Piquet
  • 1867 Answers
  • Posted on Sep 08, 2011
SOURCE: i need a diagram for
Steve,
I suggest you join up the Commodore Forum and pose your question there. You will find people there helpful. There is a sub-forum for the VT model.
http://forums.justcommodores.com.au/forum.php#holden-commodore-related
2answers
HOLDEN COMMODORE VT HEADLIGHT FAULT
check out a faulty headlight switch
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
1helpful
2answers
How do I fix my left reverse on my by commodore
Is it the globe or no power to the socket?.... Either way above your number plate you'll see the lense and it'll have a clip or screws either unclip and remove or unscrew and remove there you'll find the globes
My left reverse light don't work but my right one dose how did I fix my left one
Check the bulb by swapping with another bulb and the negative earth cable has a good contact. Does the park light and brake light work properly on that side?
Vibration when braking
holden commodores are know for vibration when braking know as brake shudder.
To correct this replace brake pads and machine disc rotors .
Clean hubs before refitting disc rotors .
Check and make sure you can achieve the run-out within holden specifications .
To achieve the correct run-out Front disc need to be under 0.5
and 0.8.
When doing run-out place front disc back on hub once all surface areas have been cleaned .
secure disc on hub with wheel nut just even so its all flush.
Then use a dial gauge and measure run if you can achieve on 1st stud move around all studs if u still cant get the front within 0.5 replace hub.
follow same procedure for rear but remember rear is0.8..
2answers
Vt commodore problems My 98 VT wagon has real
run a fault code reader to reset the abs and trac lights as the trac light uses the same sensor as the abs.. IF the pedal is still soft then there is still air in the brake system. You may have to crack the lines at the master cylinder first and bleed there first then start at the longest line and work back to the shortest
What color is the rca cord to whire up a amp in a 1999 vt commodore?
i just took wires out of a car that used to have a amplifier and they where one small light blue and one black i dont know if that helps any
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
