Question about Samsung TXN3271HF 32" TV
Resistor R410, in schematic diagram FILE NAME: power, for TV Samsung CK-5339ZB was burn, I replace with new one, but it burn again. What can be reason for this
How I check vertical?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If you are talking about vertical section 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. hope this will help. as per schematic diagram go to www.serviceinfo.com good luck
Posted on Oct 06, 2007
Samsung LN40B500P3FXZA TV has no power. Replaced bad 3.1A fuse but it blew again when attempting to power on. No obvious bad components (blown capacitors). 6.3A fuse is still good.
Since that I have not schematic diagram of your tv... I cannot figured you out the exact part number of those components that caused the problem, but the possible reason why the fuse are always blown when you turned on the unit? because there are some bad filter capacitor, rectifier diodes and power IC regulator in primary power circuit section.
Nov 08, 2016 | Samsung Televison & Video
Do you have Inotech color tv schematic diagram model no it-29?
I need 29" inotech crt tv schematic diagram(it -29).I need to replace a burned resistor but can not see the value.It's causing pincushion destortion on picture.
Aug 17, 2014 | Televison & Video
Power supply
What is the brand name and model number to your TV? Provide more details please. To give you the proper value of that resistor, i must get its position or part number. for more information go to http://electronicshelponline.blogspot.com/. It has schematic diagrams to many popular TVs' power supply. Hopes, it might help you.
Nov 12, 2013 | Televison & Video
Philips magnavox 27" tv 0/27 ohms resistance is burned what is the reason
It sounds that the resistor you indicates here is at the main power supply regulator section to your TV. It is a current limiting resistor. If it should burn, surely there must be some short circuit on the main power regulator section. Without rectifying the fault, if you replace the resistor with an other one, it might make things worse. So, check and find the reason for this resistor failure first. After rectifying the short circuit that caused for this resistor failure, replace it with a new one. OK?
Aug 13, 2012 | Philips Televison & Video
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Magnavox 27" TV- Burned Capacitor
For a schematic diagram, contact Philips directly.
Oct 04, 2017 | Televison & Video
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung TXN3271HF 32" TV Logo
290 people viewed this question
Jerry Greenberg
Jerry Greenberg
