Question about Samsung TXN3271HF 32" TV
I see only horizontal line on TV Samsung CK-5339ZB
On screen I see again only horizontal line. Resistor R410, in secondary of high voltage transformator T444, in schematic diagram FILE NAME: power, for TV Samsung CK-5339ZB was burn. Voltage in point B10-24V=0V . I replace R410 (1ohm, 1W) with new one, but it burn again. What can be reason for this
  • 032981 Nov 23, 2008
    horizontal line it 3/4 wide
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
H/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Posted on Oct 06, 2007
How to repair samsung tv high voltage vertical output
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 24, 2016 | Samsung Televison & Video
UndefinedI've checked a Panasonic crt color tv model TC-21fj20p, and I find a hard way to discover the cause of the problem until now.. The set has a good primary voltage supply. No problem with the IC...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Any short circuit at the horizontal output section circuit will shut down all the secondary SMPS voltages, as there is short circuit protection circuit to all Sony TVs.
Oct 28, 2014 | Televison & Video
My Samsung Flat screen TV went black. I still have sound.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
Jul 18, 2014 | Samsung Televison & Video
No power out
You have no power because you didn't fix 2 or 3 electrolytic capacitors when you saw warning signs. Warning signs start as horizontal lines every half inch or so. Black bars on the top and bottom, then collapsing to a horizontal line, then complete failure.
You will need a horizontal output transistor, the aforementioned electrolytic capacitors, a voltage rectifier, possibly a high voltage coil called a flyback transformer, wire wound resistor, maybe a low resistance resistor, maybe a high voltage capacitor. In some tvs you need an EPROM ic. I hope you can find someone with the knowledge and expertise these days when the modern throwaway society put almost all electronic repair shops out of business. It may cost about $300 - $400 to get repaired or you can get a modern flat-screen tv for $800 - $1,000 and reinvest that money.
Nov 27, 2013 | Televison & Video
Horizontal white lines on TV screen, all channels. I have tried to adjust everything through the menu button.
The picture tube is been over-driven by an open resistor on the video board, a quick fix is to slowly turn down the high voltage screen control on the fly-back transformer ( one is focus "don't touch" and the other is marked screen "turn anti-clockwise" until lines just disappear.
Feb 21, 2011 | RCA F25674GY 25" TV
Help me to fix the TV
Try to inspect for a loosed connection in the printed circuit board especially in the horizontal circuit. This includes the ic for horizontal oscillator, transistor for horizontal driver, horizontal output transistor and the high voltage section which includes the flyback. Pls. observe safety when dealing with these ciruits coz it deals with high voltage! Good luck!!
Apr 22, 2008 | RCA 27F650T 27" TV
Resistor R410, in schematic diagram FILE NAME: power, for TV Samsung CK-5339ZB was burn, I replace with new one, but it burn again. What can be reason for this
if you are talking about vertical section 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. hope this will help. as per schematic diagram go to www.serviceinfo.com good luck
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Standby
check secondary voltages and horizontal out put section, and check smps and all the voltages and line out put transformer section...
Sep 29, 2007 | Sony KV-32S42 32" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
JVC C-21MU1 / High Voltage Problem
Try checking the filter in the 116v line. You may have an intermittent spike coming through the B+ line.(The filter may have decreased in value) Also a small filter in the X-ray circuit could have lost capacitance. There is a low value capacitor (about .047uf @400v) in the collector circuit of the horizontal output transistor that will detune the horizontal circuit causing the HV to go too high. If this cap is intermittent it may be causing your problem. Stargazer Hope this helps
Aug 25, 2007 | JVC AV-28-BD-5-Bl 28" TV
Samsung TXN3271HF 32" TV Logo
252 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
