Where the timing mark on 1994 Mazda 323 astina
SOURCE: timing settings
you should have timing marks that are lined up on your engine. You have your crank to line up at a certain point as well as the two cams. I don't know off the top of my head where these might be for this car but you can find it in a Haynes or Chilton manual if you so desire to also learn more about your overall car and take care of this or i can find these specs and send them your way. Up to you?
SOURCE: 1989 mazda astina 323 5 spd manual clutch fluid??
Check the brake fluid resovoir, on the side there could be a hose coming off it part way down the side sharing the brake fluid to the clutch master cylinder
SOURCE: i need to set up the camshaft timing marks on a 1994 mazda b2600
its not just the camshaft timing marks you set up, you also have to have the crankshaft timing mark set right to or you may damage your engine
check the internet for the right timing procedure for you model car ok
