Does the servo led stay on? If so, you might have a fractured solder joint. Inspect the switch control PCB for fractured solder joints and check the Positive and Negative 15v outputs on the same board.
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN 1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink Car Radio Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Black/Yellow Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Blue/Orange Right Rear Speaker Negative Wire (-): Blue/White
I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
did you check fuses?
how were the wires terminated? Tape - crimp-ons - both?? Solder??
Does it light up?
Will it work on am/fm, and not on CD?
