GE GSS22SGM Side by Side Refrigerator
Problem for GE GSS22SGM Side by Side Refrigerator
Defrost timer
By tweinhold on May 02, 2009
Is the defrost timer control by the circut board?
Clarification Request
Posted by blueextc3221 on May 02, 2009
yes
Best Solution
posted on May 02, 2009
Helpful)
mnichols0205
Rank: Guru  GE Expert
Rating: 85%, 144 votes
Yes it is
Comments:
May 02, 2009
- actually the timer is inside the board you have to change the board... sorry for the missunderstanding.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
fixer1950
Rank: Wiz  GE Expert
Rating: 82%, 1175 votes
The defrost timer is basically a small clock motor that opens and shuts the freezer contacts at predetermined times. If it fails, it can be turned with a screwdriver to check it. Use the largest flat blade screwdriver that will fit into the hole. Give it 1 or 2 full turns and see if that takes care of your problem. If you hear the fridge running but still have defrost issues, it.s an airflow problem.
Was this helpful?
Yes
No
Popular Solutions for GE GSS22SGM Side by Side
Questions and Unsolved Problems for GE GSS22SGM Side by Side
Do you recommend GE GSS22SGM Side by Side Refrigerator?
Answer
Answer
The inside of both the frig and the freezer are cold on th bottom but not on the top. I replaced the... (More)
Answer
The unit has quit cooling although the compressor is still running...we pulled out and cleaned the... (More)
Answer
the freezer is no longer freezing and the refrigerator is not keeping items cold anymore
Answer
I think it is the defrost. But I replaced it a year ago. Could it be the same problem? Can i fix... (More)
Answer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
