Question about Sony Ericsson K800i Cellular Phone
Address Book Failure
Whenever I try to enter the address boon, my screen flashes white, then the screen goes black for about 30 seconds, and then the screen comes back up and it's searching for service. It started yesterday when I was opening 1 entry and doing that caused the above to happen. I tried to delete the entry and it would happen again, so I changed the name to A figuring I could change it later... but now everytime I try and open the address book, I get the above failure. I reset the fone settings, did nothing but lose my settings... Any ideas? Thanks! Bryan
  • bryUNI Oct 09, 2007
    i had to do a master reset... you may have to also...
    make sure to save all ur fone data! (fotos, address book...)
  • 490 Answers
Back up ur data, take out ur memory card  & then dial *#7370# for hard reset or contact service centre if problem persists
Posted on Oct 20, 2007
SOURCE:
Ricoh MF Copier, destination list cannot be used now, using ldap,
When it say the list can not be used, it means the hard drive/disk thet keeps your addresses have failed. The fast way would be to format the hard drive/disk and re-program your info. This commonly happens when the hard drive/disk is active during a power surge/failure or incorrect shut down. Go to service mode by pressing yellow button then 107 then hold the red/stop button for more than 5 seconds, when the screen changes press the first option on the screen(should be copy or system), now press 5832 (HD format) and enter/execute, when "completed" is displayed switch off and on. Now open your internet browser on PC, take out the web address and input your printer IP and press enter, username-admin, no password, on the left of the screen click on address book, now go to add, input all you info and press ok, now log out on the top right of the screen and test scanner.
May 01, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Find mac address
Click Start/Programs and look for the run command or the cmd prompt (black scree with white lettering). The run command might be under the Accessories folder. When the run command opens up type: cmd and press OK. The command prompt (black screen with white lettering) window will open up then type: ipconfig /all
Press ENTER. The MAC Address and IP Addresses will be shown. The MAC Address is the Physical Address for the device.
Apr 29, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
On my computer i try to get my ip adress but a little black page just pops up
To find out your IP address, you need to click on Start, then Run. In the box that pops up type in cmd and press enter.
When you get the black box with white writing (should have a :\
Oct 17, 2010 | Acer Computers & Internet
Cant find ip address on ps3
If you are directly wired to your modem (not router), you will have to reboot your modem each time you switch between computer and console. When the modem boots up, it leases an IP address to the MAC Address of the connected device. Each device has a unique MAC Address. If the MAC Address does not match to the one it leased an IP to, it won't allow access to the internet.
You can get past this by "cloning" the MAC Address of your computer to your console.
To get the MAC Address (Physical Address) of your computer:
XP: Open the start menu, click "run" and type "cmd" then hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Vista: Open the start menu, in the search bar type in "cmd" and hit enter. A black screen with white writing should have opened. Type in "inconfig/all" and hit enter. Look for the line that says "physical address". That is your MAC Address.
Now get into the network configurations on your console, look for an option of MAC Address cloning. Input the MAC Address of your computer, save and reboot.
Hope this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Im trying to find out how to update my address book in my copycenter c128
You can manually enter addresses by going to Machine Status> Tools. Add Address Book Entry and entering single entries there. Youcan also upload a .csv by browsing into the copier via the IP and going to Proprties> Services> Internet Messaging> E-mail> Public Address Book and Mapping the existing address book to your computer. It will be in a Comma Seperated Value format that can be Modified in Excel and reuploaded in the same area, but instead of mapping existing address book, Upload .CSV file to Address Book and exiting.
Mar 05, 2009 | Xerox CopyCentre C128 Black and White...
Address Book
the phone need to be flash , so take it to a mobile service center and have that done.
Aug 21, 2008 | Motorola Mobility RAZR V3
Address book
Select the Address Book application from the main screen (with all the icons.) The address book icon is black and white in the default theme.
Press the "Menu" button (just left of the trackball)
Scroll up or down to "New Address" and push the trackball in (select the menu item.)
Fill in all the details that you have for the contact.
Press the "Menu" button again (left of the trackball)
Scroll up or down to "Save" and select it by pushing the trackball in.
Bob's your uncle!
May 28, 2008 | AT&T Blackberry Curve 8300 Smartphone
Set up e-mail address in Canon 5020i
1) press the * (star) button with the head shape around it
2) on the screen touch on "Address book Settings"
3) Touch on "register address"
4) Touch on "E-mail"
5) in the bottom left hand corner of the screen touch on "Register New Address"
6) Touch on "e-mail"
7) Touch on "name" and enter the recipients name and press "OK"
8)Touch on "e-mail address" and enter the recipients e-mail address and press "ok"
9) Touch on "ok" again
Repeat steps 6 - 9 to add additional addresses otherwise touch on "done" 4 times to exit the menus
If you wish to register the e-mail addresses in the one-touch address book, follow the steps below:
3) touch on "one touch buttons"
4) touch on an empty block
5) touch on "register/edit"
6) touch on "e-mail"
7) touch on "name" and enter the person's name and press "ok"
8) touch on "one touch button name" and enter the person's name again (here you're restricted to 12 characters so you may need to abbreviate it somehow) and press on "ok"
9) touch on "e-mail address" and enter the e-mail address and press "ok"
10) touch on "ok"
repeat steps 4 - 10 to add more addresses. or touch on "done" 4 times to exit the menus.
May 09, 2008 | Office Equipment & Supplies
Address Book
you need to have the phone firmware reflash and service, then if that does not work get a new phone...LOL
Mar 26, 2008 | Motorola Mobility RAZR V3
Display screen
that is wierd - you can try the first solution to have it flashed, but 30% that's the answer, somehow your lcd probably burnt out so a simple replacement is required - it would cost about $30-40 for the lcd and the installation
Jan 24, 2008 | Motorola Mobility V262
Sony Ericsson K800i Cellular Phone Logo
96 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
