Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite clypso
Will not spin. does not show any error code everything else seems to be working.well the nucturater sometimes will not work. with the top up I can get it started.The belt is good. When doing an automatic service diagnostics test the desplay (in seconds) remains at 80. If you can help I will be grateful.
  • 290 Answers
I think you have 2 different problems. The nutator not working sounds like a bad leveler. Remove the nutator and the dome. Pull the leveler off the shaft and see if one of the springs is broken. Every time I have run across a machine that would hang in diagnostic mode I have had to replace machine control board. The purpose of diagnostic mode is to actuate every part of machine. The only time it should not complete cycle is when it finds a fault, shuts down, and displays a fault code.
Posted on Oct 08, 2007
  • Anonymous Oct 14, 2007
    Just wanted to follow up on your washer and see what you found out.
    Thanks/Mike
SOURCE:
My Kenmore Elite Oasis HE model # 110.2706 stopped working during the middle of a load and showed an F 50. Tried to unplug it, restart it and tried the clean machine mode. Nothing is working.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
136 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
