Defrost isn't working, replaced every part possible including the board. After a little over a week the freezer side is so frozen that the cold air doesn't travel into the refigerator side.
Comments:
May 02, 2009
- Where is the timer located? I figured the board controlled that?
- the timer is usuall located on the back of the refrigerator; there should be a label or a small hole that you can put a blade screwdriver in turn it clockwise you should hear a series of soft clicks as you turn the timer; the compressor should shut off and defrosting should start after a few hours the mullion heaters should stop defrosting and the compressor should start again if it doesn't start replace the timer let me know how it goes
The inside of both the frig and the freezer are cold on th bottom but not on the top. I replaced the...
(More)
The inside of both the frig and the freezer are cold on th bottom but not on the top. I replaced the defrost unit already but that did not work. My refrigerator same model number and everything is doing the same thing. It did this on and off for a few weeks and now has quit cooling altogether. It seems to stay at about 55 degrees in the fridge and 45 degrees in the freezer and the bottom is cooler than the top. I was told to find the owners manual and that it is the main computer in the fridge that is preventing it from cooling as it should
The unit has quit cooling although the compressor is still running...we pulled out and cleaned the...
(More)
The unit has quit cooling although the compressor is still running...we pulled out and cleaned the coil thouroughly and put back but still not cooling.
I think it is the defrost. But I replaced it a year ago. Could it be the same problem? Can i fix...
(More)
I think it is the defrost. But I replaced it a year ago. Could it be the same problem? Can i fix it myself or do i have to call the experts?
(More)
