It works, but does not cool at all.
Oh no. Most of these systems do not come from the factory with service ports that allow you to add R-134a. You will need to buy a clamp on piercing valve then add the refrigerant. The leak is most likely in the evaporator coil where the wine is stored, and the R-134a will leak out again soon. Replacement or repairing the leak will take care of the issue, also the weight in ounces of refrigerant should be on the data tag of the unit next to the model number. Try not to exceed the recommended charge.
