Question about ViewSonic VX924 19" LCD Monitor
Won't turn on
Hello! I was given this monitor as the original owner was going to trash it, but I thought I'd take a look at it to see if it's repairable. It won't turn on. The LED on the power button will blink faintly when it's plugged in and NOT connected to a PC (no vga cord attached). ONce it is connected to the PC with the VGA cord the light stops blinking and nothing else happens. Power supply? what to check first? Thanks in advance!
  • petri Oct 05, 2007
    Yeah...looking at the circuit board (Power supply and invertor), there's at least 3 bulged capacitors...they are located very close to the promary transformer...the board itself is brownish, looks like excessive heat..
    If I replace these bulged capacitors, it should help, but what else should I check?
My monitor died and wouldn't turn on. Found 3-4 of the electrolytic capacitors had bulging tops and a dead short across them. Removed the caps but the short remained. Found the mbr10100 to220 packaged dual diode rectifier had a short across one side. Replaced the capacitors with Pansonic 10,000 hour
units and the 10 amp mbr10100 with a mbr20150 20 amp rectifier which brought the monitor back to normal operation.
Jack
Posted on Nov 22, 2007
    Guru:
  • 120 Answers
Could be a power supply issue. Maybe it's not getting enough voltage from the power supply unit. Could also be some bad solder points on the circuit board, or maybe a burnt capaciter.
Posted on Oct 04, 2007
  • Peter Downey
    Peter Downey Oct 06, 2007
    Check for bad solder joints. I've had bad solder connections on monitors before that were shorting out the board.
    The capacitor problem is more than likely your problem. Replacing them will probably solve it.
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
GO VIDEO UNIT
hi,
Please clean the disc lens with the lens cleaner.
Jun 30, 2008 | GoVideo Go Video DVD/VCR Combo
Xtreme Flat KDS 19" monitor got a burned smell,
This monitor should be trashed, CRT monitors are not worth repairing. LCD monitors a cheap and energy efficient.
Jul 19, 2011 | KDS Xtreme Flat 9e 19 in.CRT Conventional...
Hello, i just bough the gateway monitor FPD1975W but i can not to connect because it asking for passcode. what i culd do? thanks
This is bad news, you will need to get it fromt he original owner and you alos need to contact GATEWAY, please see below:
http://www.fixya.com/support/r4558549-gateway_lcd_monitor_eztune_theft
Please leave rating if it helps.
Feb 16, 2011 | Gateway FPD1975W 19" LCD Monitor
Hello. I got given a compaq presario 700
motherboard is not alright. there are failing compaonents on the motherboard( capacitors, resistors e.tc). however, try to go to bios and stay there for some time and see if the same will happen.
Regards
Feb 11, 2010 | Compaq Computers & Internet
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
EMachine W3107 will not boot, no display.
Have you tried a different Graphics Card, looks to me like the onboard graphics card is at fault, there should be an AGP slot or PCI slot that you can plug a new Graphics card into then you should be fine...
Sep 04, 2009 | Computers & Internet
Screen went Blank (Black) with no Power Indicator
the VGA cable for a CRT monitor is the same as the VGA cable for an flatscreen monitor. The VGA protocol hasn't changed between the two technologies, so if you tried it with a different known working cable and it still didn't work, then it is the monitor, and not the cable.
Does the monitor's power led turn on? If not, it could be a power supply issue. Unfortunately lcd monitors are not very user-servicable. There isn't much in there that you can touch if you crack it open.
Jan 24, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Analogue LG Flatron
the monitor is working ok if it goes to safe mode with no input.which do you turn on first?(to work out which could be faulty)It is most likely that the monitor data cable is the fault(at either end) or the PC m'bd disp skt,try pluging an add on disp'card in to the PC. Regards Chook.
Apr 24, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
ViewSonic VX924 19" LCD Monitor Logo
170 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
