Question about Asko D3731XLHDSS Built-in Dishwasher
Asko - Model 1996
My (five year old) dishwasher has the following issues: Makes some eerie (whistling? high pitched?) noise while running. Doesn't drain all the way Leaks out front corner (see doesn't drain all the way) Occasionally during a cycle it will start thumping - it sounds like it is bumping against the cabinets. So - couple of questions. Should I be calling appliance repair (motor?) or a plumber (clog in line)? I have 1) taken out the filters to see if there is debris (none) and 2) put baking soda and vinegar in to see if that helps.
  • hpaddict Oct 04, 2007
    I did baking soda and vinegar as the "old fashioned" remedy for clogs - as this is what people did in the days before drain-o. As for elbow grease - yup - last I checked I think I knew what that means!
    In all - I'm still trying to see if the problem might be the motor (or a pump issue) in which case I'll call for appliance service - or if people think it might be a plugged air gap/line - in which case it is a plumbing issue. Just trying to find the right trade for the job.
    Ah - but now you have as I'll be calling appliance repair for a motor!
  • 209 Answers
Running any appliance that makes a noise can only make matters worse and cause more damage to the machine, if baking soda / vinegar and other cleaning and food items would cure faults then they would be sold saying use for dishwashers on the label, waste of money using such things, if your cleaning pipes out just use elbow grease ( oh just in case you ask where to buy it, (elbow grease is a term for hard work) sorry it may be that you have not cleared out the filters etc properly, thats why it doesn't empty all the way, also check the outlet at the wall see if thats clear also leaking, check seals for wear and kinks or damage, replace if signs of above, thats all you can do there to cure the leaks sorry
Posted on Oct 04, 2007
  • mick d Oct 04, 2007
    glad you saw the funny side, my expertise is 20 years as an appliance engineer but that that did involve little work on dishwashers, the screeching could be a dry bearing on the main motor, its just a question of if the main motor is also the pump motor in one (in some cases it can be) then the motor is the problem
    while we engineers do our best it never takes the place of actually being there listening to it live, where a good engineer would just say " yes its that and be 99% right)
    best of luck sorry i have not helped you as you wished
Makes high pitch whistle
Do you have the brakes taken apart once a year,
on all your vehicles, for rust removal,inspection,
needed work & lubing,that is required
Have to flush brake fluid every 2 years, if you
don't want moisture in the system ruining it
Don't know what the noise is,work on the
brakes & then get back to the noise, if it's
still there
Jul 24, 2013 | 2010 Mercury Milan
Makes a whistling noise when in use
I had a problem with my LG dishwasher and there was a small stainless steel impeller that they had to replace to stop the high pitch noise. I think this impeller grinds up any food particles. The tech said if one of the veins bend it causes this issue.
Feb 10, 2013 | LG 24 in. LDF 7811 Built-in Dishwasher
Lg 3850dd3006e makes noise
I had the same issue with my LG it has a stainless steel impeller the grinds up the food particles and if one of the veins get slightly bent it causes that problem. The tack took it out straightened it out until the new part arrived and it worked fine. He did return to replace it but I don't think it was needed
Jul 29, 2012 | LG 24 in. LDF 7811 Built-in Dishwasher
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 14, 2012 | Whirlpool Washing Machines
My 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Please check my following tip for the full solution to your problem.
Click here -> L.G E1 Error / Whistling Sound
Kind Regards :-)
* If you found this solution helpful, please rate it.
Jul 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
2003 Mercury Grand marquis utlimate edition Whistling noise coming from the rear and eerie annoying.
What speed?
In the trunk area?
Around the rear doors?
Only in crosswinds? Sometimes the antenna makes a whistle noise in cross winds at 50 plus mph.
Get a roll f 2 inch masking tape, and tape off areas one at a time and test drive.
May 12, 2009 | 2003 Mercury Grand Marquis
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Asko D3731XLHDSS Built-in Dishwasher Logo
545 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Marvin
Marvin
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
