Question about Hitachi 46GX01B 46" Rear Projection Television
Bad picture The unit is almost 9 years old. So I'm wondering if it is worth fixing. The unit gives off a not so clear image. I have tried to make adjustments to to contrast etc. and no better. Is it worth repairing or not. And what do you think it may need.
  • Deeter21 Oct 05, 2007
    Techman said the Big Screen TV might have Bad Power Supply Capacitors. What does that mean and can those be changed. I have tried cleaning totally inside , lenses etc.
    President:
  • 3,130 Answers
Have you taken the front screen off yet and cleaned the lens and mirrors? Dust and dirt, and specially nicotine gets on these surfaces and clouds up the picture really bad. If you clean the set and this does not help, you probably have bad picture tubes, and I would not invest in new tubes at this point, or there could be bad power supply capacitors. Good Luck
Posted on Oct 05, 2007
  • Larry  Dillon
    Larry Dillon Oct 05, 2007
    If you do not know what capacitors are my friend, you should not be messing around inside this TV set.
SOURCE:
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
My Hoover floormate motor started smoking. It is over 9 years old. I keep the floor brushes clean. I am wonder if replacing the mother is worth it.
MSRP on this motor is $69.95. Labor may be another $30.00. I often see these units in thrift shops, which may be worth a try.
Jan 29, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the unit until recently. It seems the compressor isn't coming on, but there is an occasional...
The starting relay may be the culprit and is very inexpensive to replace. It is probably worth fixing.
After it is fixed, make sure you get the condenser fins cleaned.
Dec 12, 2010 | LG Refrigerators
My AIWA TV 19-inch color is 9 years old. It is
HI,
WHEN WORDS AND PICTURES ARE BLUR,DIFFICULT TO SEE,,
ITS PROBLEM WITH LOT (LIGHT OMITTING TRANSISTOR) WHICH INSIDE TV ...
NOT OTHER PROBLEM ..JUST GO TO ECONOMIC TV TECHNICIAN.
TNKS
RABBANEES
Nov 12, 2009 | Aiwa F2000 20" TV
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Xbox 360 lights are green but it says mode not supported on the tv screen -no picture at all -even tried another tv and heard the audio at times but no picture-all cords intact-no ventalation problem...
Bad very bad.
It's bad solder connections under the G.P.U.
Trust me I know, I re-flow about 2-3 a day .
but the units are normally about 2 1/2 -3 years old
and 60% are Microsoft reworks. you can tell this by
a black dot on the safety seal .
You have 2 options Fix it you self , if done right you should
get 2-9 months sometimes more.
Or have a shop re-flow the G.P.U. . cost 80.00 or so.
you should get 3-12 month hard to say with these unit.
Rob
Nov 02, 2009 | Microsoft Xbox 360 Console
Gives me a small grunting noise than stops and seems ready to cook. Its a 9 year old 1300w genius and has been problem free till today. Thanks, rr
well i never a 9 year old microwave,,, time it found its way up to the dump yard then, by now you must have had your money's worth out of it, is it realy worth paying out to try to get it fixed up??? dont be silly, buy a new one, and have a nice flashy one for half the price
Oct 20, 2009 | Panasonic NN-T990SA Microwave Oven
TV has sound but no picture
Everything is worth fixing provided the price is right.  However, in this case it's probably not cost effective to repair the unit.  Start with the easier fixes, such as bulbs, etc.  Even then, some of the components can be quite expensive, or simply unavailable.  I would suggest getting a quote from a local repair shop in order to make an informed decision before you get to far into it.  You could end up spending just as much to repair it as you would on a new unit.
Oct 19, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Help: My tv picture has started going blurry
The picture tube is going bad,not worth repairing,better invest in a new set. The rating response is important to the person helping you.
Oct 11, 2006 | Samsung TXN2734 27" TV
Hitachi 46GX01B 46" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
