Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60pp9202 sound no picture
"Sorry no pic, but if you look from back of set on deflection board(board with HV transfromer)big part with about 4 wires coming out going to your picture tubes. Looking close to leftside of board the last IC with heatsink shield standing up has a small 7 pin ic if looking on it you should see TDA8177 or something to that affect. This is the verticle IC. Since you have found the IC's (convergence) then the only thing left is to look for open fuses like 1300, 2004, 1900 etc and see if open. Concerning cost if you buy from www.bluestaronline.com these part are inexpensive so it wouldn't hurt to buy all. Rule of thumb, if set has color problem then Convergence IC, if no problem just went out one day while playing fine then Vertical, then the alternative if no sound the audio area, which is not common for this set. Hope this helps!" O.k. change the vertical IC,still experienceing the same problem. the rear projection tubes are barely lite up. Could it be the flyback(the thing with the 4 red wires going into it from the tubes. Is it hard to change. where could i get the part.
  • joe-eeee Nov 18, 2007
    Exact same problem. Vert IC did not help ! I sent out board for repair !
    They say if you replace the IC's there could be a blown transister and this
    will destroy the new IC you just installed. Let's see if the re-furbed board
    does the trick. I will post !
    President:
  • 4,402 Answers
The quick answer to you problem is critical in what your set was doing prior to it shutting down. Do you remember it having a Color problem like alignment of convergence? Was the sound cutting out on you? Or was there part of the picture missing? If one of these then you could eliminate time and money. To be honest you would save money DIY. You also can call PTS at 18008447871 and get the price on Deflection board or Large Signal, whichever has High Voltage Transformer on it and price. This will save timephilips 60pp9202 sound no picture - 1.gif troubleshooting2.gif, because it takes the knowledge of knowing voltages, components, etc. Which require skills the average person may not have. Hope this helps!
Posted on Dec 14, 2007
No picture and makes a squeaky noise when turned on
A Philips with the high pitched whine or squeaky sound has a short usually on the deflection board (the middle board) which can be anything from a cap to the high voltage transformer.
It indicates the set has a short and is in shutdown.
Dec 07, 2012 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
NO PICTURE BUT HAVE SOUND.
Thats a deflection issue. The deflection circuits will need to be checked on that madel as thats the HD DPTV chassis. It may be cheaper just to get another LSB ? deflection circuit board to put in it. You can get one at the following link which they have one for about half of what they normally go for and they include free shipping. Heres the link.
http://servicemanuals.vstore.ca/
Jun 29, 2008 | Philips 60PP9202 60" Rear Projection...
SOUND BUT NO PICTURE
try resoldering the vertical output IC. have seen bad solder on that model make the picture tubes blank as a safety feature when vertical deflection drops out.
Mar 12, 2008 | Philips 60PP9202 60" Rear Projection...
RCA Big Screen
maybe deflection board or hv block that put the set in shutdown mode if you are not a tech this is a job for one ..
Mar 09, 2008 | RCA P52926 52" Rear Projection Television
Philips 43PP8545
The most common problem is convergance amp ic, but with out troubleshooting it's hard to pin point whats wrong.
The quick answer to you problem is critical in what your set was doing prior to it shutting down. Do you remember it having a Color problem like alignment of convergence? Was the sound cutting out on you? Or was there part of the picture missing? If one of these then you could eliminate time and money. To be honest you would save money DIY. You also can call PTS at 18008447871 and get the price on Deflection board or Large Signal, whichever has High Voltage Transformer on it and price. This will save time1.gif troubleshooting2.gif, because it takes the knowledge of knowing voltages, components, etc. Which require skills the average person may not have. Hope this helps!
Oct 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 rear projection hdtc
The quick answer to you problem is critical in what your set was doing prior to it shutting down. Do you remember it having a Color problem like alignment of convergence? Was the sound cutting out on you? Or was there part of the picture missing? If one of these then you could eliminate time and money. To be honest you would save money DIY. You also can call PTS at 18008447871 and get the price on Deflection board or Large Signal, whichever has High Voltage Transformer on it and price. This will save time troubleshooting, because it takes the knowledge of knowing voltages, components, etc. Which require skills the average person may not have. Hope this helps!
Sep 21, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 sound but no picture
Sep 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
