Question about Evenflo Embrace - Rainforest
Carseat straps i got a carseat from a yardsale and i need to lower the straps but there is a little black box thing how do i get it off?
You can move it by pushing down on the flexible tab part of the seat base just above the box, but you don't need to move it at all in order to adjust the straps.
In order to move the straps I remove the clip side (the opposite side of the box), this removes in the same manner as the black box side, you just push down onthe flexible tab on the base; and run it through backwards, slide it into the next hole up, to make it larger run it back through the holes and click it back into the base in the back of the seat. This can all be done without disabling, The clip in the front of the seat must be unfastened but it will all fit through the holes in the seat to adjust the straps.
Posted on Nov 10, 2007
SOURCE:
How to remove maxi cosi cabrio harness straps
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Mar 22, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Straps have been washe and need to know how to putr back together
Hi
The harness straps should not be removed from the carseat shell due to the safety implications of them being re-fitted incorrectly. The carseat would need to be sent to the engineers for re-fitting the harness. What country are you in and we can direct you to the relevant customer care team to discuss this with.
Feb 18, 2012 | Maxi-Cosi Axiss Reflection Booster Car...
Cannot refit maxi cosi car seat straps after washing
Hello - The harness straps of any carseat should not be removed as the re-threading of them requires specialist tools. Due to the safety implications of the harness being incorrectly re-fitted, the carseat would need to be sent to the engineers for inspection and repair as required. If you're in the UK please contact the customer services department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Aug 13, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
The car seat for baby has very short harness straps. Where can I order an extantion for harness straps?
There is no such thing as an extension for a carseat harness - it would be unsafe. The carseat harness has ample length for your child but will require extending as per the user manual to fit around the child safely.
Sep 28, 2010 | Maxi-Cosi Priori
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
How to lower straps on evenflo infant carseat
You're trying to unattach the straps from the wrong end....flip the car seat over and on the very bottom there is a little gold clip that pops out and you can push through the hole.
May 19, 2009 | Evenflo Embrace
Cosco car seat
Purchasing used car seats at yard sales etc is illegal! The seat could have been damaged or could easily break because it is used. Goodwill doesnt even sell them because it is against the law. Save a life and buy NEW. The seller was wrong to do this. Never save a dime when it comes to safety! Strollers however are ok to re-sell.
Figuring out those straps are tricky and can cost a life if not done right. If you insist on keeping it, make an appointment with the calif. hwy patrol or police dept in your state and they will install the seat safely and propery for you. Do not do this yourself,please!
Mar 16, 2009 | Cosco Baby Gear
Need Extension Straps for 2007 Maxi-Cosi infant carseat
hello boss why dont u contact the same place where u have bought the carseat earlier(4 months back).. i guess he can be very help ful to u..
Feb 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Sep 23, 2007 | Baby Gear
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Evenflo Embrace - Rainforest Logo
121 people viewed this question
Top Evenflo Baby Gear Experts
Ekse
Colin Stickland
Colin Stickland
rebecca curry
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
