Question about AT&T Partner 18 Phone (315805B)
Dedicated fax line on system phone
How can I determine what extension is hooked into our dedicated fax line?
    Novelist:
  • 201 Answers
If you have a dedicated fax line, the fax should be connected directly to the phone line. If you have the fax line connected to one of your station ports, you may be able to see which LED lights up on your phone when the fax goes off hook. Or you can just try intercomming all extensions in order until the fax rings.
Posted on Oct 05, 2007
SOURCE:
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button.
If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no.
Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
Mar 24, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
We have three lines incoming. when line 1 is busy the second call on line 2 will not ring on other extensions.we have 4 extensions but call goes straight to the answering service on extension 5. Is this a...
This could be a setup problem, however I suspect you may have a "smart ring" set up with the telephone company. If this is so then it won't work. If the 3 lines are dedicated, then there is something wrong with the PBX.
Oct 04, 2010 | Office Equipment & Supplies
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
Stand-alone fax machine share the line of a business extension?
Only for outgoing faxes. You would need fax server software to receive
Feb 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Can send but can't receive faxes.
if your fax is on a dedicated fax line, make sure your display says "fax only" or "auto". if not on a dedicated line, you'll have to give more info on what kind of hook up you have. in other words, is there an answering machine hooked inline, etc.
good luck,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
I have never hooked up my fax portion of the 6100 hp.
You should have a dedicated ANALOG phone line.
Hook phone cord from wall jack to LINE port of the fax machine.
Ready to fax.
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't receive fax - fax rings 2ce then just stops / says phone off hook
Hi Iryan,
Instead of switch box, a more dependable option is to get a distinctive ring. Your local phone company offers this option. What's neat about is you get a seperate fax number. Its like having a dedicated fax line without adding extra lines to your service. I think the monthly fee is around 3 dollars a month for this feature, but, believe me its well worth it.
anaanymous
Jul 15, 2008 | HP Officejet 4110 All-In-One InkJet...
Weboughta 1040 fax machine. our phone system is bell canada. the answering system and call waiting will not work when fax is hooked up
Fax machines are designed to have their own dedicated analog phone line.
Any other condition is a **** shoot.
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
AT&T Partner 18 Phone (315805B) Logo
394 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
