Question about Dell E153FP 15" LCD Monitor
Monitor blanking out,
Monitor blanks out, same as previous reports, suggestion to replace caps makes sense, which caps?
  • retiredroger Jan 05, 2008
    From Retiredroger, I think, not sure, another web site got closer, by naming the Cap as C2, and,as a 1000uF cap, found same in a likely loc., did solve the problem. Thanks for the suprising reply, Ill be back someday to cruise the site.
    Problem Solver:
  • 14 Answers
I would start at the power supply section , just locate where the ac cord plug to, and that will take you to the power supply area,
please stick with the same values if you can , but never go below the voltage rating on that capacitor, you wil have a pleasent surprise if you dont.
Posted on Jan 04, 2008
On my hp 6520, the text on the Print Quality Diagnostic report is flawless yet the black ink box on the report is blank. Makes no sense! Saved documents and scans come out blank, any ideas?
if its not an original oem cartridge ink level wont show. clean cartridge head with isopropyl alcohol. blow through top hole to force ink through could be blocked as ink dries on contacts
May 03, 2018 | HP Office Equipment & Supplies
Monitor screen goes blank after few seconds, turn power off and back on, works for a few seconds and goes blank again. Any suggestions? connections are tight
It can be due to bad poweer supply caused by bad DC filter caps, bad backlights inverter circuits, bad lamps assembly. It will require in-depth trobleshooting.
http://s807.photobucket.com/albums/yy352/budm/SONY/
If you are going to DIY repair, please read below first.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Nov 03, 2011 | Sony SDM-HS74P/S 17" LCD Monitor
Picture comes on the goes blank, reset power does the same condition pix for 2 seconds then goes blank. - power supply keeps proper voltage - top inverter transformer was squeeling the repklaced board - no...
You can still have bad backlights lamps, that is why the transformer is squealing due to poor connection on the wire at the lamp connection, the output of the inverter voltage will try to go up to keep the lamp firing and draws too much current and cause the inverter circuits to shutdown. The inverter has two detection circuits: over current and open lamp sensing (it will sense if the lamp will fire up and stay on).
Look for burnt/harden wires on the lamp assemblies.
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 02, 2011 | ViewSonic VP930b 19" LCD Monitor
Hi, Have installed an Nvidia Geforce 7600GT on my PC but got an error Frequency out of range. Installed latest drivers can get a desktop but no icons or task bar tried properties, arrange icons, checked...
The PC video resolution is too high, native resolution for this monitor is 1280x1,024 @60Hz.
It does not make sense thogh thst you get blank sceen on safe mode, you may have video card set up problem. Does it work with another PC? Cna you try another monitor with thsi PC?
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Mar 10, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor is blank. comes on momentarily when i reboot but goes back blank
The problem can be the backlight inverter circuits, bad caps in the power supply, or bad lamps. I would inspect the caps first, look for caps with bulging tops, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 12, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor with a blank screen
The monitor is about 2 years old, time to inspect the caps in the power supply first, look for caps with bulging top. The problem can also be in the inverter circuits, or bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can help you more.
Mar 01, 2010 | ViewSonic Q191wb LCD Monitor
How can i fix my lcd monitor it just went blank can't see nothing at all??
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and look inside first and report back what you see so we can guide you further, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | ViewSonic VX910 19" LCD Monitor
Optiquest q20wb Screen goes blank after powering on
I'd like to report a success story. I had this same problem with my Q20WB. It sat for over a year in my garage. I eventually bought replacement capacitors, soldered them in, and now it works. You can find kits with the right capacitors preselected, or if you feel like it you can also buy them individually.
good luck
Mar 02, 2009 | ViewSonic OptiQuest Monitor
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Blank Screen
This is a CCD problem that Nikon is correcting at no charge - go here to find more details: http://www.imaging-resource.com/badccds.html Click on the Nikon link for a form to fill out.
Nov 19, 2006 | Nikon Coolpix 5700 Digital Camera
Dell E153FP 15" LCD Monitor Logo
71 people viewed this question
Clive
Clive
Alun Cox
