Question about Motorola Mobility RAZR V3c Cellular Phone
Mic not working
My motorola handset while i talking not giving my voice to other end. what i have to do?
    Brigadier General:
  • 7,752 Answers
Replace the microphone on the phone.
Posted on Jun 29, 2008
SOURCE:
Motorola v3i earpiece problem, if i switch on the loudspeaker means i can here the voice but at the other end they cant here my voice my mic goes off like mute at the same time if i switch to ear speaker...
You have to use one or the other. If you use the earpiece or headphones, you have to use one with a microphone in it. If you use the speaker in the phone, you have to choose it from settings during the call and use the phone's microphone and speaker.
Mar 02, 2018 | Motorola Mobility RAZR V3i Cellular Phone
When someone calls me they can't hear me talking on their end of the phone, but I can hear them.
Sounds like you have a bad microphone on your handset. Probabaly not worth fixing with this older phone model. Check with your carrier to see what upgrade options you have. Most prepaid carriers have newer phones for less than it would cost you to fix the mic on this phone.
Sep 30, 2010 | Motorola Mobility W315 Cellular Phone
I am getting the voice from other end & my voice is not going
Mic issues can be tricky. Knowing what operating system you are using would help diagnose the issue.
First the simple things. Make sure your mic is plugged into the correct jack. It should be red. Second, you need to open your sound mixer and make sure your mic is not muted or the volume turned all the way down. Either of these will cause you not to be heard.
You can also open the sound settings in your control panel, it is the icon that looks like a speaker if you are using Vista/7. Under the recording tab, make sure you see your mic/headphones/etc (what ever you are using as a mic) in the list. Make sure it has a green check mark on it indicating it is the default device. You can then double click it and select the levels tab to ensure your volume is not all the way down on the mic. You can also click on the listen tab. Place a check in the listen to this device box and click apply. You should now be able to hear your own voice as you speak into the mic over your speakers. It gives you a way to troubleshoot the mic functions. Once you can hear your voice, remove the check and click apply again to return to normal.
Make sure you can hear your voice without Google Talk. It most likely is not the application causing your problem. If, however, your mic works on everything but Google Talk, then we need to do more troubleshooting. Let me know if this resolves your issue.
Mar 06, 2010 | Google Talk
I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Jul 22, 2009 | Uniden DCX640 Cordless Expansion Handset
I need a user manual for thisSFK404 Bluetooth Visor Mount Handsfree Speaker but I cant seem to find one online so i could download it
didnt find any either too old but here is specs.
Model No: SFK404
Simply attach the Visor to the Sun Visor or any other suitable place, connect the Bluetooth hands free kit up with mobile and away you go.
Superb Quality simple Bluetooth Car Kit with Caller Id Display and Number Keypad for easier dialing.
Specifications
* Talking Time : 5 Hours * Standby Time : 150 Hours
* MIC : -47+/-1.5 * Power Consumption : Max 250mA
* Carrier Frequency : 2400MHz to 2483.5MHz * Transmission Power : Typ.1.0 dBm
* Operating Temperature : -20 ~ 70? * Storage Temperature : -40 ~ 85?
* Speaker : 8W, Max 1.5W * Digital Volume Control
* AC/DC Adaptor : 5.0V / 1A * Car Charger : Out : 5.0V/800mA
* Battery : 3.6V, 950mA Li-ion Rechargeable NK8200 series compatible
Main Functions
*Superior noise suppression *LCD Display - Caller ID/Calling time
*Excellent echo cancellation *Support Making/Ending a call
*Super full duplex *Support Voice Dialing, Number Dial
Compatibility : Compatible with all Bluetooth mobile phones
Profile : Supports for both Headset & Handsfree Profile
Bluetooth v1.1 compliant
CSR(BC02)
CDMA & GSM & TDMA
- Approvals : SIG, CE, FCC certified
FEATURES :
Last Number Called
Voice Dialing ( Providing the Phone Supports the feature.
Number Dialing
Speed Dialing
Selct wether to answer, Reject and End Calls
Volume Control
Power On and Power Off Feature to reserve battery power.
Rechargable Battery
Battery Power Status
Incoming Caller Alert ( Visor will Play a Meldoy and the Led Display will Flash Blue )
Connect to Pc for firmware upgrades ( Cable Supplied )
Bulit in Speaker
Built in Microphone
Bulit in 4Mb Memory
Noise Suppression
Echo Cancellation
Supports both Headset and Car Kit Profiles ( Phone Dependant )
Transferring Audio Feature ( Both from Headset and Handset )
Standby 150 Hours ( Uses a Nokia 8210 Battery so you can have a spare battery or simply purchase any nokia phone model in car charger to charge from your car. )
Talk Time 5 Hours
1 Year Warranty
Compatable with all Bluetooth Enabled Mobile Phones.
Handset supporting headset profile
Ericsson: R520m / R520m, T39 / T39m / T39mcc, T68m / T68mc
Sony Ericsson: P800, T68,
Motorola: A803, T280i, TimePort 260C V1.1
Philips: Fisio 825/826
Samsung: X7700
Sky: IM6200
Handset supporting handsfree profile
Motorola: V525, V600
Nokia: 6310 / 6310i, 8910 / 8910i, 3650, 6230, 6600, n-Gage
Sony Ericsson: T68i / T68ie, T610, T613, T630, Z600
Siemens: S55, S56, SX1
Panasonic: X70
Jan 22, 2009 | Cell Phones
Phone works fine except the person on the other end can not hear your voice. Phone is a Uniden DCT 646 series cordless phone with one addional handset. The additional set is working fine.
There is an inexpensive built in mic where you speak into the handset. Ifit is not clogged with any debris, the mic needs to be removed with a soldering iron and replaced with a like one from Radio Shack.
Aug 23, 2008 | Lands Phones
People can't hear me!
There is no problem with your handset ....This problem is due to the loose contact by the mic ...
if you are good at opening the handset then just open the handset and then have a check near the mic ....
then try reconnecting everything .......
if problem persists then replace the mic with the new piece ...
the mic too much cheap to purchase .... but while purchasing just tell your handset model and take the compatible mic .........
after replacing there will be no problem at all from any end .......
your set is fine ... you dont have to worry too much ...
just spend a very very little money to take a new mic and replace it..
if you are not good at opening then just visit the technician ..........
any doubts reply me
i am always here to assist you
thank you
bye
Dnt forget to rate the solution .............
Apr 29, 2008 | Motorola Mobility V220
Cell phone
It seems your mic problem. Mobile phones microphones are are used to get such defect. Motorola mic is ractangle type SMD(surface mount device) and replacement needs some skill. If you don't have enough knowledge please don't try to do yourself. Give it to skilled technician, he will replace it with new one but will charge you little.
Jan 09, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola razr v9
you need to have the mic on the phone board replaced.....so take it to professional mobile store to have them replace it.
Nov 17, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
