Question about Protron PLTV-32 Television
The source keeps changing automatically
I bought Protron PLTV-32 about 2 months ago. Since I bought this TV, the source (TV, Component 1 and 2, AV1, etc...) keeps changing automatically. For example, while I am watching a DVD connected to AV1, the source automatically changes to AV2 and the screen loses the signal. I called Protron 3 times, and each time I was told to keep the source switch off for 30 minutes, but it did not solve the problem. Is there any way to fix this problem?
  • 4 more comments
  • Anonymous Nov 03, 2007
    TV keeps turning itself off; jumps from Component 1 (where I watch cable) to something else entirely. I tried the solution posted, turn off at set, unplug for 30 min., turn on at set, this is supposed to reset the TV to original settings (some said) but it is not a solution, the set still does its thing. Maddening. Any solutions?
  • Anonymous Nov 04, 2007
    I too have the same issue, it seems when I have the tv turned on for a few hours it starts to do this, it seems to me like a heat issue. I can turn the tv off for a few hours to cool and than it works again for a while.
  • DP2007 Nov 21, 2007
    I bought this TV in March 2007. It was the last one on the floor and I got it for a steal. No wonder! The source button continually switches out. While I'm watching TV it switches to DTV. It can happen 10 times in 20 min of TV watching. No telling when this is going to happen. Heat? I have no idea. Then it was happening in the morning, but not the evening so I thought there was something in that- crazy I know. I am ready to get rid of it, but I can't stand the thought of being wasteful. I'm not willing to pay $175 to mail out. I think I may buy the same TV somewhere and return the OLD one in the box and get my money back. The store will mail it to back to Protron and THEY can accept the loss as they have not been helpful in fixing this problem.
  • Anonymous Nov 27, 2007
    i have the same problem,still working on a fix,will post,were can i get parts for this tv ?
  • Chatton Nov 28, 2007
    Thanks everyone.
    Sounds lots of people are having the same issue.
    I finally decided to return this TV.
    Fortunatelly, the seller issued a full refund.
  • kateekw Nov 30, 2007
    Same problem. Source switches. But there are times when it doesn't happen in a day that is why I thought it might be some outside influence like communication eqipment. I live in the country where there are a lot of gas wells and compnaies run up and down the road all the time with all sotrs of equipment. But maybe the heat? Heat in TV or remote? Not real clear on that solution.
    Katee
  • 4 Answers
This does seem to be a heat issue,
Posted on Nov 28, 2007
  • Anonymous Nov 29, 2007
    hello,the problem is in the manual control unit itself, it would be a easy fix ,if i could fined parts for this tv ,,? if you remove the back cover then remove the screws from the back board on the touch control it pops off ,and the problem is gone of course you still need to get the part,after you remove the little board you can change the control operation with a flat tip on the solder points at the plug 14 of them,any help on locating parts thanks
SOURCE:
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
Tip
Protron PLTV-32 Manual Download
Download Spectroniq Protron PLTV-32 LCD TV Manual
Would you like to review the features of the Spectroniq Protron PLTV-32 LCD TV ?
Have you lost your Spectroniq Protron PLTV-32 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Spectroniq Protron PLTV-32 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Spectroniq Protron PLTV-32 LCD TV documentation.
I hope that helps.
___________________________________________
Protron PLTV-32 Service Manual Download
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | Protron PLTV-32 Television
How do I get rid of the following from screen... Main: Component 2 Sub: TV Note the main, component 1 failed years ago...
If you want to get rid of the display, you should have a DISPLAY button on the remote, just press that.
Feb 25, 2011 | Protron PLTV-32 Television
I get no picture or power to the tv
Unplug the TV for 15 seconds
Plug in and turn on
set source to av1
select menu
select and enter Setup
select and enter All Reset
If you are able to do this your TV should work fine
Dec 02, 2008 | Protron PLTV-32 Television
Tip
I hope that helps.
on Jul 05, 2010 | Spectroniq Protron PLTV-32 32 in. Plasma...
My PROTRON LCD PLTV 32 IS BLACK & DEAD
LOOKING FOR A AC ADAPTIR MODEL :090-02180-13
Oct 03, 2008 | Protron PLTV-32 Television
My Tv ramdomly switches source and Protron Spectroniq is of no help
Changed source to av1
select menu
select and enter all reset
If you are able to do this your TV should work fine.
Feb 03, 2008 | Protron PLTV-32 Television
I had a pwer supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is [email protected].
Dec 29, 2006 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
607 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
