Question about Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator
Freezer Problem Freezer stops working when ice maker is switched on and starts to defrost. Only makes ice when on fast freeze. Once ice is made we switch maker off then leave fast freeze on until temp is made. Freezer is fine as long as ice maker is off.
  • 114 Answers
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Posted on Oct 05, 2007
Freezer not staying frozen and ice maker not making ice
Sounds like your fridge guy is right. Just be sure coils are defrosted again when new heater is installed.
Sep 22, 2017 | Electrolux Refrigerators
Avanti 1008W
To manually defrost just unplug unit from power outlet for 12 hours,it will automatically defrost.But if these problem is occurring again n again then issue is with defrost assembly parts,the defrost timer,the thermostat and temp sensor in freezer section causing the problem.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice maker doesn't work.model kbfa25erss01
Hi and welcome to FixYa, I am Kelly.
Often when ice-makers stop working the real problem is that the freezer is not cold enough (It must be 14-16F for the icemaker thermostat to cycle) Check for signs of ice or substantial frost in the back of the unit / evaporator coil area. If you have ice / frost in this area you should do a manual defrost by unplugging the unit and directing an external fan into the freezer compartment for about 2 hours while it makes a water mess that will need to be tended too. Once the 2 hour thawing is complete wipe up the excess water and return the unit to normal service. If the problem was caused by excess ice it will operate normall for 2 - 3 days before ice production slows or stops totally. Should the manual defrosting correct the icemaker problem you most likely have and automatic defrost problem in the form of a problem with one of these 3 components:
1. Defrost control
2. Defrost heating element
3. Defrost thermostat
Having said all of that... You can use this manual to check out your icemaker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Make sure to test the coils on the inlet water valve for continuity. If one of the coils is open *** must be replaced. The inlet water valve is NOT repairable.
Your water valve can be found here:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-water-inlet-valve-item-number-ap4080917.aspx
Here is another link on how to test out the icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The ice-maker thermostat must be at or belw 16 F for the above tests to work.
NOTE the freezer door LIGHT switch must be taped down also.
Before you get too deep into troubleshooting checkout the freezer door light switch first. If the switch is bad the freezer compartment light will not work and the ice-maker also will not work.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | KitchenAid Refrigerators
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
Freezer does not freeze some items completely and ice maker not
Replace the defrost timer. Take your make and model number to appliance part store and get a defrost timer. Relatively cheap and usually easy to change...
Jan 04, 2009 | Amana Refrigerators
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
Nov 30, 2007 | Maytag PTB2154G Top Freezer Refrigerator
Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator Logo
150 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
