I have a brother's label maker P-touch 1100QL
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
SOURCE: need instructions for my little 1100QL P_Touch Brother machine.
follow this link:
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&c=as_ot&lang=en&prod=1100eas&type2=5&flang=English&dlid=
*please rate me :)
SOURCE: ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
I have a similar product, PT-1010. Margin can be set using -> -> . However, the product always waste 1 more inch of tape to provide an additional preceding margin and ask me to cut it off by hand using scissors. I can't find a way to disable the preceding margin.
