Question about Microsoft LifeCam NX-6000 Webcam
Microsoft webcam 1.2
I had this working.now all i see is black when trying to get on skype. the actual device flashes....th4e audio works and has been tested but NO video. any help? i have re booted
I would suggest you look on the skype forums. Apparently, It is only fairly recently that skype has encompasses video calling too, and there are still some bugs.
This is the direct link to the video chat ection of the forums - good luck ;)
Posted on Dec 29, 2007
I can't get the webcam to work when I am calling someone on skype
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X right click to reinstall drivers or update driver W7. Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service Open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call. Make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment. Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings. Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it Hope this helps.
Dec 18, 2012 | Microsoft Windows Vista Home Premium with...
Not working with skype
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
Dec 19, 2010 | Microsoft LifeCam HD5000 Webcam
Everything works except the person I call cannot hear me. I am using skype. The echo check on skype works, I have tried two other cameras and I have the same problem. No matter how I change the settings...
The Camera and Audio setups are unrelated in both Windows and Skype. Please check your Windows Audio devices volume settings and specifically the Microphone settings: it appears to be disabled or the volume level set much too low. The windows settings overrides the settings in Skype (or in other words, Skype volume settings are a subset of the Windows volume settings). Check that Skype audio is setup properly after starting Skype: Tools -> Options -> Audio Settings -> select your required devices and volume levels. During this ajustment process, make free calls to Skype 'Echo / Sound Test Services".
Hope it helps! Let me know how you go!
Dec 31, 2009 | Microsoft LifeCam VX-5500 Webcam
Initialization error
Test your webcam here by hitting "Allow" in top window and assessing your webcam in left hand panel.
If it works here, you know the hardware is OK. Now you have to configure it to any program you want to use it in
SkypeIf you have problems when you use your webcam device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your LifeCam device as the default microphone. For example, select Microsoft LifeCam VX-3000.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your LifeCam device as the default Webcam. For example, select Microsoft LifeCam VX-3000.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
I do not know the second program ( explorer express) but there will be a similar arrange for making your Hardware default
Aug 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
I am new to using a web cam. I purchased the VX6000 and everything is working, however, the people I talk to on it only see static pictures of me (Skype).
I think what they are seeing is the photo you took with your webcam when you set up your account.
Make sure your webcam is is working OK and then check your settings
  1. Start Skype.
  7. Click Save.
Aug 20, 2009 | Microsoft Lifecam 6000 Webcam
Lifecam vx-3000 WITH SKYPE
hello,
Kindly try to reconfigure your webcam to SKYPE application. To set up your webcam for Skype, please follow these steps:
1. Download and install the most recent drivers for your video device (you can get these from the webcam device’s manufacturer’s site). In many cases this is not necessary if it is a USB device. Note if you have driver on your webcam you can reinstall or install it. Make sure that the driver can support the current Operating system you installed in your system.
2. Select your video device in Skype by clicking the following from the Main Skype Control window:
Tools -> Options -> General (tab) -> Video Settings (tab)--if video
Tools
-> Options -> General (tab) -> Audio Settings (tab)
-- if audio
3. If your webcam is functioning you will see yourself displayed. If you are not seeing yourself be sure you have Enable Skype Video checked/Audio Cheked. If you are still having difficulty click Webcam Settings.
Please note: FireWire devices are not supported at this time.
4. Make sure the option Enable Skype Video/Audio is checked. Also you can set video privacy settings to the desired options in the same window.
5.The recommended System Requirements for Skype video calls are a 1Ghz CPU, 512MB RAM, a video card with at least 16MB of memory (also the latest version of DirectX installed) and a 512/256kbit (down/up) connection. Video and call quality may vary greatly in environments with conditions below those recommendations.
6.
Please be sure, that your webcam is connected and not in use by another program.
Thanks
Jul 31, 2009 | Microsoft LifeCam VX-3000 Web Camera
Microsoft Life Cam vx3000 black screen
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, on left panel, go to down and click on Super Webcam and click on Start Super Webcam Mode Automatically.
  5. Then click APPLY and then OK.
  6. Next click on MESSENGER and then click on MY WEBCAM and you camera should BRODCSAST and you will see your picture.
Hope this helps. Bud
Jul 30, 2009 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam vx-3000 used with Skype
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Feb 10, 2008 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam NX-6000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
