2007 ram 3500 6.7l diesel,cannot figure out how to reset the message center console warning message"oil change required" was told to turn on and off key rapidly 3 times to clear but it did not work. Only when I change oil in the dealer do they reset or turn off this message. Can anyone let me know how to do it?
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye: 1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET 2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK 3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW 4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL 5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100% 6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows: 1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK 2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL 3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100% 4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
AnswerEasy get an oil change at a garage and have them erase the code or do the oil change your self and then disconnect the neg battary terminal.
Easier AnswerOn the console, where the oil change light is on, scroll through the items until you get to oil life. Once at oil life, hold the reset button and it will say Engin oil new? Press reset again and this should set you oil life back to 100% without needing to disconnect your battery
Complete Answer 1- Turn on the ignition without starting the car 2- You will get warning messages on the display (including the "change oil soon" or "oil change required" message) press reset for each warning till you get the Odometer displayed. 3- press the setup button until "press reset for system check" appears 4- hit the reset button (need to do this fairly quickly, if you end up back at the odometer go back to step 3) 5- the system will scroll through the different things that are wrong that it has detected, you should go to "oil life XX%, Hold Rest New" message first if nothing else more major has been detected. When on this message hold the reset down unit you get the message "if new oil hold reset". 6 - hold the reset down till the message "oil life set to 100%" appears (note have seen different wording in some models) 7 - system should scroll through any remaining messages and then return to the odometer reading Switch the car off and on and confirm that the message does not reappear. Have seen some instances where will not reset, if so take to your dealer.
Message Center Configuration Oil Life Reset - Message Center Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days
Press and release the SETUP button until the message center displays PRESS RESET TO BEGIN SYSTEM CHECK.
Press and release the RESET button until the message center displays HOLD RESET IF NEW OIL.
Press and hold the RESET button for 2 seconds and release to reset the oil life to 100%.
The message center displays SETUP MENU HOLD RESET.
Oil Life Reset - Base Instrument Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days.
Place the ignition in the RUN position with the engine off (KOEO).
Press and release the TRIP/RESET button until SETUP MENU HOLD RESET is displayed.
Press and hold the TRIP/RESET button until SYSTEM CHECK is displayed.
Release the TRIP/RESET button.
Press and release the TRIP/RESET button to scroll through the system check menu items until HOLD RESET IF NEW OIL is displayed.
Press and hold the TRIP/RESET button until OIL LIFE SET TO 100% is displayed.
Release the TRIP/RESET button. The oil life is now reset.
Oil Life Start Value - Message Center Cluster
NOTE: The oil life start value is used to reset the oil life value back to the maximum of approximately 8,000 km (5,000 miles) if the value was previously changed or to lower the value from the maximum (8,000 km To reset the oil monitoring system to 100% after each oil change [approximately 5,000 miles (8,000 km) or 180 days] perform the following:
Enter SYSTEM CHECK to display "OIL XXX% OIL LIFE OK".
Press RESET control to display "HOLD RESET IF NEW OIL".
Press and hold RESET control for more than 2 seconds. Oil life is set to 100% and "OIL CHANGE SET TO 100%" is displayed
You can disconnect your battery for 15 minutes or pull the fuse for an ECM or PCM fuse, but the best way is to visit any local repair shop. Most shops will have a universal Check Engine Light Code Reader that can quickly and safely reset check engine light trouble codes. It should take about 30 seconds. Ask your local service center if they could reset the check engine light with a Check Engine Light Code Reader.
Resetting the MINI Oil Indicator If you do your own oil changes, this is a helpful tip to keep in mind. Typically, it is best to wait until your dealer maintenance service warranty expires, as an ‘owner’ reset could result in a missed oil change, particularly if the dealer checks the indicator it does not believe an oil change is due.
1. Locate the trip odometer button and depress and hold. 2. Insert the key into the ignition and partially turn into the first position. 3. Pay attention to the trip odometer to display the word ‘RESET’. 4. Release the trip odometer button, then press & hold it again. 5. The ‘RESET’ message will flash. 6. Release the button, and then press & release again (once only) 7. The service interval is now reset to 10,000 miles
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed.
Ford Five Hundred, Freestyle, Mercury Montego 2005-06 Tap the ODO/TRIP button to toggle the display between the odometer and trip odometer. Tap on the ODOiTRIP button again to toggle the display between the trip odometer and OIL LIFE % display. Press and hold the ODO/IRIP button for 2 seconds or more to display OIL LIFE 100%. Your oil life in now reset.
Good luck and print this and keep it in the glove box. Keep me posted if you have any other questions
Press and hold the SELECT/RESET
control switch to select SYSTEM
CHECK when “SYSTEM CHECK /
HOLD RESET” is displayed in the
message center. Selecting this
function from the SETUP MENU
causes the message center to cycle through each of the systems being
monitored. For each of the monitored systems, the message center will
indicate either an OK message or a warning message for two seconds.
Pressing the SELECT/RESET control switch cycles the message center
through each of the systems being monitored.
The sequence of the system check report and how it appears in the
message center is as follows:
1. OIL LIFE RESET
2. CHARGING SYSTEM
3. WASHER FLUID
4. DOOR AJAR
5. EXTERIOR LAMP
6. BRAKE SYSTEM
7. PARK BRAKE
8. MILES TO EMPTY
9. FUEL LEVEL LOW (will only display if 50 miles or less to empty)
following:
1. Enter SYSTEM CHECK to display
“OIL XXX% RESET IF NEW”.
2. Press SELECT/RESET control
switch to display “HOLD RESET IF
NEW OIL”.
3. Press and hold the
SELECT/RESET control switch for
to 100% and “OIL CHANGE SET TO
100%” is displayed.
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset A press of the OIL CHANGE RESET switch will allow you to reset the oil life feature to 100% (or your Personalized Oil Reset Percentage). After you have the oil changed, you must execute the following procedure. Press the OIL CHANGE RESET switch and hold for five seconds as the M/C counts down for five seconds. After a successful reset the Message Center will display “OIL LIFE RESET TO 100%.” If you have established a Personalized Oil Reset Percentage, the display will show that percentage instead of 100%. To ensure accurate oil life indicators, perform this reset procedure only after an oil change. Your Personalized Oil Reset Percentage allows you to establish a smaller oil change interval than the manufacturer’s recommended interval. To establish your Personalized Oil Reset Percentage perform the following procedure: 1. Press and hold the OIL CHANGE RESET switch and press the RESET switch while the display is still counting down the 5 seconds to reset. The display will change to “START OIL LIFE AT XXX%.” 2. Press the OIL CHANGE RESET switch until the displayed percentage is the Personalized Oil Reset Percentage that you desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%, 40% and 30%.
