Question about Cuisinart DGB-500 Coffee Maker
Delayed brewing when brewing coffee, sometimes the process stops after 2 cups (of an 8-12 cup cycle) and will just sit there - - no more brewing and the coffee that did dbrew is luke warm at best. Maker is approximately 4 years old.
  • stillgoinnut Jul 26, 2008
    In order to complete the cycle we have to turn off the grind then hit brew again. This process is repeated about 4 more times until the pot is full
  • lwright60 Aug 08, 2008
    I am having the same problem. Set for 10 cups, brews 4 and shuts off. Mine doesn't come back on like some I've read. Are there solutions to fix this?
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
  • 8,596 Answers
You all have posted different problems - everyone: try cleaning with vinegar/water solution - 2 cups vinegar, 2 cups water
For everyone else:
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Posted on Dec 17, 2008
  • zach
    zach Oct 14, 2014
    I have a lot to write but I will keep it short. Your idea worked. Left the solution inn overnight halfway through cycle. Next morning finished the cycle and back it up two 12 cups of fresh water. I also had a filter to catch anything and found small piece of hard deposits in the filter.
SOURCE:
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-500 Coffee Maker Logo
800 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Norman Worley
Ekse
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
