Question about Hoover F7431-900 SteamVac Vacuum
Middle spinbrush falls out of hoover maxextract all terrain 60 carpet cleaner after the assembly was taken apart for cleaning
I removed the spinbrush assembly and took the clear plastic casing off the row of brushes to clean each round spinbrush individually. when i put it all back together and went to use the carpet cleaner, the middle brush wouldn't stay in place if i lifted the cleaner off the carpet at all. did i break whatever was holding the middle brush in place?
Buffalo12980
  • 625 Answers
SOURCE: ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Posted on Sep 22, 2007
reddevil6
  • 1673 Answers
SOURCE: middle brush problem
If this is new, get it replaced under warranty. Take your model number, serial number, proof of purchase and the brush block with you, or you may be able to do it at hoover.com.
Posted on Jun 09, 2008
  • 157 Answers
SOURCE: hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Posted on Oct 06, 2008
SOURCE: Removing nozzle on Hoover Steamvac
I'm sure you have found a solution to this problem by now, but I am having the same problem removing the nozzle, and just read another persons post where they suggested buying the "Nozzle Clean-Out Tool" available on Hoover's website for $1.00 plus $5.00 in shipping. The part number is 39514001. It worked for this person, so I'm going to try it. Not a big investment, at least, in case it doesn't work!
Posted on Nov 30, 2009
ftw1952
  • 10319 Answers
SOURCE: hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Posted on Jan 24, 2010
How to replace tank support ***.#41423021 ?
Hey there! We recommend taking the cleaner in to a Hoover authorized service center to have the tank support repaired or replaced. Follow the link to locate the nearest location to you.
Service Center Locator
Thanks!
Jul 31, 2014 | Hoover F7411900 Maxextract Dual V Carpet...
Tip
Hoover Platinum Collection Carpet Cleaner with MaxExtract Technology making...
The cleaner does it's job well. Using on standard short carpet.
The problem so far is after 6-8 uses it started making a grinding noise when pulling backward.
Brushes still spinning just had the noise and the unit still functioned properly.
I only use it about every 3-4 months to clean 3 rooms.
The last use the noise got worse as it was making in forward and reverse motions.
The noise would usually start after using it for 5-10 minutes.
I figured it might be a slipping belt on the beaters and probably water was getting on the belt making it worse.
I removed the circular beater assy by just pulling it out.
Removed the round front beater by removing 3 screws, 2 at each end and one holding the belt guard on towards the middle. Once the beater is loose slide it out through the belt.
The front beater cogs for the belt had some black build up in between several cogs.
I cleaned the cogs very thoroughly, checked the belt for wear and checked the motor gear. They looked ok.
Assembled in reverse, did a quick dry test but didn't fill all the fluids to do a full test. That will have to wait till next time.
Please don't hold me accountable if you try this and break something, the cleaner is made mostly of plastic and the pieces can easily break. Don't try unless you are willing to take the risk, it may void warranty if it gets broken.
If problem still persists then will try using the 6 year warranty that it supposedly has... From what i've read it might be a pain getting it fixed under warranty.
Here are some visuals. http://s1139.photobucket.com/albums/n559/dmayfield1/Hoover/
fell free to contact for questions.
on May 27, 2012 | Hoover Vacuums
Download hove maxextract floor finishers model
Hi! Follow the link to view the owner's manual for the Hoover F8100900. http://hoover.com/file/622/
Thanks!
Jul 07, 2014 | Hoover F8100900 Carpet Cleaner with Max...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
No water spraying
here is the manual > http://hoover.com/file/600/ go to page 17 troubleshooting.
Apr 16, 2013 | Hoover Maxextract 60 Pressurepro Carpet...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Brushes will not rotate on my steam vac
I am having the same problem also as I can see many of you are having. I've only had my hoover steamvac dual V carpet cleaner for about a month and only used it once, then used it about a month later and the brushes no longer spin. These steam cleaners aren't cheap either, mine was over $250 and only used it once before malfunctioning. Obviously this is a huge problem because I've searched the web and there are many complaints about the spinbrushes on these units.
Nov 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hover F7452-900
Regarding the brushes not turning:
Your filter may need to be cleaned. It is located behind your brushes. With your tanks removed and the cleaner unplugged; tilt your cleaner back. The filter screen located behind your brushes can be removed by squeezing the sides of the filter and lifting and pulling toward you. Clean and replace.
It would be difficult for me to advise you any further without seeing exactly what you have done.
Aug 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
