Question about Sony Handycam DCR-PC5 Mini DV Digital Camcorder
Eject mechanism issue.
When I open the outer door to the tape load and eject region the left side of the tape cage pops up. the right side stays closed. So the inner frame appears twisted. Left edge doesn't catch and stay down. Tapes get stuck. Interested in a repair estimate.
  • 752 Answers
The estimate depends on the extent of the damage... if it is just a matter of reallignment I would estimate $50-100 at most shops. But based on your description, it sounds more likely that parts of the transport are irrepairably bent or broken and will need replacing, which would put the estimate around $200-350.
Posted on Oct 04, 2007
SOURCE:
Can't eject tape
"first remove the power to the unit, pop the top lid off, (4 screws) then u will see a controle board secured on top, there are 2 screswes on teh side, becareful not to break any of the wires connected to the board when sliding out of the way. below this board is where the tape is located. You should notice a number of visable plastic grears onthe side of the loading mechanisim. there reall is only one u need to be concerned with, It is Located on the left side of the motor, motor is located to the rear left side of the mechanisim. there u will see a long a FLAT gear, just to the left of the motor, there is a small amount of play in this gear, push this geer twords the rear of the unit and hold it there, reinsert the powersupply and press eject, this will tigger the eject mechanism and pop the tape out"
Feb 14, 2013 | Sony DSR-11 DV / Mini DV VCR
Can't open door - can't eject tape
How old is your camera?
Seems it has weak capacitors in circuit.
Oct 27, 2008 | Sony Handycam CCD-F555 Camcorder
Sony mhc-2600 tape stuck
The tape has spewed out in the mechanical section preventing the door from opening, some outer doors can be removed by too thumb screws sliding up and out, others are held in by plastic clips, the door may have to be pried open to get the outer door off to remove the tape.
Jul 27, 2012 | Sony Audio Players & Recorders
Well ont eject all the way out
There is a problem with the loading basket, or the VHS tape is stuck inside and the eject mechanism can not cycle the tape out. To check this, open the lid so you can see the tape, if it is wrapped around the head and roller, hit the eject button to see if the tape is being pulled or jammed, cut the tape with scissors to free it up to see if it will pop out. If the tape is okay, it means you have a faulty loading basket.
Dec 30, 2010 | Samsung VR3607 VHS VCR
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Sony Handycam DCR-PC5 Mini DV Digital Camcorder Logo
125 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
